on the n75 I got one but it has the wrong connector. are you sying they are the same just a different connector on the end? thanks bob oh guess I will need a different pigtail then just rig up one?
there are only 2 types of n75's ones that work with boost, and ones that work with vacuum. there are 2 types that work with vacuum and the way that they work is the same. just the connector is different.
