frank_h71
- Joined
- Nov 9, 2018
- Location
- Beaver Dam, KY USA
- TDI
- 2015 Passat SEL TDI, 2014 Beetle Convertible TDI "Molly's Ride", & 2004 Jetta Wagon TDI my commute car
All,
I have a 2004 BEW 5 speed Jetta Wagon. I has about 260K on the ticker.
I have had it for about a year and it have put about 20K on it myself. Most all maintenance is up to date. Gonna need a basic service soon.
Here is what happened this morning. I went out to head to work. Usual Monday morning.
1. I tried to start the engine. It started. DRL's came on. I slide it into REV and the engine dies.
2. Crank it again. It starts. Start to let the clutch out it dies.
3. Think I might need to glow. Maybe? Temp in upper 40s to lower 50s and haven't started since Thursday afternoon when I got home from work. Turn on key. Notice no glow light. Look a little closer and don't have any indicator lights except battery. I didn't even have a odometer or clock in dash. I go ahead and give it a crank it starts and dies in about 3 seconds.
4. Will continue to crank with no start after this. Had to push out of the way of the wife's beetle and even with the key on the windows would not roll down.
I didn't have time to check anything. My thoughts in order are:
Ignition switch not making ignition circuit. Maybe a fuse, but shouldn't I have a odometer? Might have been to dark to see it this morning.
No power to ECM/PCM "brain", but would it crank?
Mystery open fuse link?
Let me know your thoughts?
Headed home to check on the waggy. Got an hour to think about it. Don't know if VCDS will tell me anything if no ECM/PCM power from ignition.
Thanks,
Frank
Thanks,
Frank
