Right, but the TSB and the more well known issue is for the NMS Passat. It has a different HVAC system, different EGR system, and a different engine, that is evidently more prone to this problem. TSB clearly states "CKRA only", which is the TDI engine in the NMS Passats through 2014.
I bring this up to the OP because often if there is a TSB for something, even if you have to spoon feed it to the dealer personnel, you may have a better time of getting them to actually address the problem and in some cases get it covered under a warranty extension.
