vr6 clutch/g60 flywheel ok to use w/ .234 nozzles vnt 17/22?
Texas_sky
ATX/Mile Hi
2001 GOLF TDI 2dr 5spd
What would you think the highest level of psi I could run the turbo at w/o destroying the clutch? Recommend a stage 3 or 4 tune? Planning on a FMIC as well.
mk1-83
Holland
LUPO 1.9 tdi 300+ hp
It will hold fine when You let the torq come easy in the powerband.
450-500nm at 2500 rpm.
NewTdi
NorCal
2003 Bora, Reflex Silver
I ahve a RC stage IV, OPP764 and VNT something bigger turbo and so far so good on the VR6/G60 clutch/flywheel combo.
Texas_sky
ATX/Mile Hi
Anyone else with similar setups? What is the life expectancy of the clutch with a set up like this?
