Ac compressor, which one?
kylec922
United States
2006 jetta tdi
My compressor, or should I say the solenoid broke. Looking to buy a replacement but I can't for the life of me decipher which compressor is in my car. Any help is appreciated.
kdawg89
Spanish Fork, UT
15 Golf DSG 06 Jetta (sold)
look at the compressor and look at the piece that the electrical plug plugs in to. Whether it is held in with a snap ring or bolt should tell you all you need to know. Probably worth checking that the compressor also has a Sanden label on it, as long as it hasn’t been replaced with an aftermarket along the way it should.
kylec922
United States
2006 jetta tdi
So the Sanden is a hog ring? I looked for a label never saw anything, fairly certain a ring holds it in. Aren't there different Sandens though?
kdawg89
Spanish Fork, UT
From the factory they were all Sanden, there are 2 different Sanden models though, one used a snap ring and one used a bolt to hold the RCV in. If you look at it is should be very obvious which it is. Either a bolt will be holding it in or not.
