Old August 18th, 2018, 16:22   #1261
Dan C.
Originally Posted by kjclow View Post
The only numbers that have been published were for the 09-12 model years and that was with the NHTSA investigation. I'm going from really fuzzy memory but I want to say that came out to around 3%, which is probably wrong. To get a better number, you'll either have to dig through the long closed original HPFP failure thread or look on the NHTSA site and see if any of the investigation paper work is still available. I've seen nothing since the investigation was closed.
NHTSA claims less than 800 individual concerns/complaints.....
'97 B4 Passat 397k sold!
'09 Jetta 6M 200k VW bought back Jan '17!
'05 E320 CDI fast fast, wrecked! rebuilding into a project hot rod
'15 Passat SEL Premium DSG
Dan C. is offline   Reply With Quote
Old August 23rd, 2018, 10:19   #1262
Michael B
Just to update everyone on my situation. VW retested the fuel and surprise, no change in the results of their test. (User error? Anomaly?) And VW, even with my third-party fuel report saying the fuel meets the state standards of diesel fuel quality, denied the warranty claim.
The better news, is that the dealership's service manager is going to fix it under goodwill, and only charge me a 350 dollar "Deductible". This headache is almost over. 78 days later. I can pick up a loaner vehicle today, too. Woo! The dealership has been very good - the service manager even has told us he believes the state test is accurate, and more comprehensive than the VW test. I am very glad the service manager was working hard to help us.
Michael B is offline   Reply With Quote
Old September 22nd, 2018, 17:46   #1263
mrorganic
Fuel Economy: Not sure but around 40
Default HPFP failure
Year: 2012
Build Date:
Make/Model: Jetta Sportwagen
Tranny: DSG, 6M: 6 Speed manual
Mileage: (actual miles at time of problem or when problem began): 90,000
Diesel Fuel Source: (Shell, Exxon, etc.): Mostly used Union 76 And Conoco.
Additives: (Yes/No): No
Problem: (HPFP failed, fuel canister rusted, etc. Give as much factual data as you can.): At about 90,000 miles my check engine light came on, Tried to fix this myself at just over 91 miles i took it to the dealter, dealer said there metal in the fuel at the N290 Valve, Also found P0401 fault, will require replacement of DPF. DPF is covered under the Warranty extensions.. VW declined the fuel system repair.
Was told this is due to the car not having Fuel Guard Kit in it.
Dealer: (ex. SmokeAndMirrors VW or VW of Fallacy Idaho):: Overturf VW, Kennewick, Washington state. I think the dealer wanted to do the repair but so far VW has declined to cover the warranty that they gave and said that my car had.
Status: (still pending, dealer fixed everything, resolved, dealer refused, paid out of pocket): At this point VW has refused to do this repair. I have an attorney that is working on this.
All of the HPFP failures that i have read about were almost immediate. My car will still start and run but i am not wanting to run it and maybe cause more damage. If i have to have the repairs done my self, i want a CP3 HPFP but have not been able to find one. When the attorney lets me know, i will post the outcome. So I am not happy with VW at this point.
mrorganic is offline   Reply With Quote
Old October 5th, 2018, 14:37   #1264
ooopie
Originally Posted by mrorganic View Post
[B]
Did you have the Dieselgate emissions fix done to the car already? If not, can you do the buyback asap while the car is still running?
ooopie is offline   Reply With Quote
Old November 7th, 2018, 22:32   #1265
Wheels57
Thumbs up HPFP Failure
Year: 2010
Build Date: 2009
Make/Model: Volkswagon Jetta TDI, 2.0 Litre NARCOMFC
Tranny: DSG, 6M Auto six speed.
Mileage: (actual miles at time of problem or when problem began) 159812 km
Diesel Fuel Source: (Shell, Exxon, etc.) Shell
Additives: (Yes/No) No
Problem: (HPFP failed, fuel canister rusted, etc. Give as much factual data as you can.) HPFP Catastrophic Failure. Metal chard spread throughout engine.
Dealer: (ex. SmokeAndMirrors VW or VW of Fallacy Idaho) Royal Volkswagen, Vernon, BC, Canada
NOTE: This was a sudden failure. There was no warning. Car was being driven moderately. (Had cousin on board from overseas on a sightseeing trip).
Original quote was $13,000 CDN, right before we were considering trading it in due to DieselGate. Was told it needed to be functional to receive $5,500 compensation otherwise it would be $3,000. Contacted VW Canada. Conclusion: Reduced to $11,000 CDN. VW Canada footed 90% of the bill and dealership Turner Volkswagen in Kelowna 5%. I paid 5% which was $521.51
Now I get 77,000km or three years warranty but not bumper to bumper. Reason the dealership and VW Canada paid. I had always had the vehicle serviced when due and on time. I looked around for a replacement and quite frankly everything else is sluggish in comparison. Very happy with my TDI. Pity VW have chosen to stop manufacturing them. Electric will not be the same!
Wheels57 is offline   Reply With Quote
Old December 17th, 2018, 12:14   #1266
EffinNewGuy
TDI(s): 2013 JSW
Year: 2013
Build Date: Unknown
Make/Model: Volkswagon Jetta Sportwagen TDI, 2.0
Tranny: DSG
Mileage: 48,448
Diesel Fuel Source: QuikTrip (Up to 5% Bio in South Carolina, guaranteed fuel)
Additives: No
Problem: CEL after fill up. No other symptoms noted (no loss of power, no flashing glow plug indicator, no flashing CEL). Metal shavings and rust in HPFP and clogging screen of HPFP. Dealer pulled fuel sample for in-house sniffer test. Claims fuel failed due to gasoline contamination. If this gets pressed, I will pull my own fuel sample and submit for DRO/GRO, %water analysis. Will also send a sample for additional analysis, if needed. Tech stated samples sent to Europe get a more detailed analysis, and that he has only seen 1 fuel sample pass the in-house sniffer. He stated it analyzes for gasoline vapors (BTEX, I imagine).
Dealership has stated that fuel system will be replaced under warranty.
Status: Pending repair. Dealership is replacing under warranty.
EffinNewGuy is online now   Reply With Quote
Old December 17th, 2018, 20:04   #1267
Smokin_Joe
Exclamation
Originally Posted by EffinNewGuy View Post
Year: 2013
Build Date: Unknown
Tranny: DSG
Mileage: 48,448
Additives: No
For your own piece of mind you should capture a sample of the fuel from the tank asap. The lift pump probably rusted out because of VW not using stainless in the rods...starving the HPFP. That is where our problems started. http://forums.tdiclub.com/showthread.php?t=410742
Good Luck
Joe
(These are my opinions based on my experiences, I have more than enough tools to be dangerous and enough age to forget how to use em..lol)
From Canada eh!
Smokin_Joe is offline   Reply With Quote
HPFP Failures-State by State List dweisel VW MKV-A5 Golf/Jettas 219 October 5th, 2016 17:57
List of HPFP Failures Silver02TDI VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 38 November 16th, 2010 17:59
How many HPFP failures? MayorDJQ VW MKV-A5 Golf/Jettas 1 July 30th, 2010 11:51
Page generated in 0.17159 seconds with 11 queries
[Output: 86.53 Kb. compressed to 76.05 Kb. by saving 10.47 Kb. (12.11%)]
