Old September 17th, 2018, 18:29   #76
HANSEN1937
Originally Posted by 1945GPW View Post
Hey Guys!! I'm new to the form but have had diesel VW's for about 6 years now. I am more familiar with the MK4 Jetta's but recently purchased a 2015 Golf TDI and I'm really liking it.
Anyway as the title says I'm experiencing a longer than normal cranking period the very first start of the day. After that initial long start it starts normally through the day. What I mean by long crank is the engine turns over approximately 4 to 6 times before it starts. After the first start of the day it will crank about 2 turns and fires right up.
Is anyone else experiencing this and if so whats the fix for it? My golf has 24000 miles. I replaced the fuel filter and its not any better. I'm thinking the HPFP is possibly de-priming over the night causing the extra cranks, what are your thoughts? thanks
There is an excellent video on U-tube explaining and demonstrating the repair.
The link: Vw golf 2.0TDI EA288 long crank diagnose P0341/P0016/P0011
See DIAGNOSE DAN.
HANSEN1937 is offline   Reply With Quote
Old October 1st, 2018, 04:40   #77
dj7373
So any new updates on this issue?
I'm also getting long starts on the first start of the day and I'm worried that it might become an issue as it gets colder.
D.J.
Stock
Stage 4 custom Malone tune, VNT 17 etc. (will be a swap engine)
dj7373 is offline   Reply With Quote
Old October 11th, 2018, 19:20   #78
RockRockRock
TDI(s): SHOPPING
I had this issue after putting in a cheaper fuel filter and getting the Stage 2 fix... So I couldn't tell what caused it.
The dealer mentioned the battery was on the way out. I put in a new battery and the car hasn't done it except for the first crank.
Theres a crazy sensor suite on new cars. Need to feed it plenty of angry pixies.
RockRockRock is offline   Reply With Quote
Hard start .... long crank syndrome AndyBees VW MKIV-A4 TDIs (VE and PD) 19 October 4th, 2018 16:48
99 Golf long crank time to start rrraabit VW MKIV-A4 TDIs (VE and PD) 18 June 16th, 2016 21:29
Long crank white smoke on start up dieselg33k VW MKIV-A4 TDIs (VE and PD) 9 May 18th, 2012 17:11
long crank time to start '04 PD tdi jetta 2004PlatinumTDiSport VW MKIV-A4 TDIs (VE and PD) 7 May 8th, 2012 19:07
long crank and white smoke after start oh-man67 VW MKIV-A4 TDIs (VE and PD) 17 January 30th, 2012 09:30
Page generated in 0.11787 seconds with 12 queries
[Output: 60.87 Kb. compressed to 55.58 Kb. by saving 5.28 Kb. (8.68%)]
