Old October 9th, 2018, 19:57   #16
sptsailing
sptsailing's Avatar
Fuel Economy: 44 typical, 38 minimum, but as high as 50
Follow up 2 months later:
1. Repairs cost about $3000 for parts, many of which are just expected maintenance, now also including a replacement battery that it needed but an injector harness that I later realized it really did not need
2. Car is working great now, with 43 mpg for city driving with air conditioning during Florida summer
3. A 2006 Jetta with a 5 speed manual continues to be a great car
Last edited by sptsailing; October 9th, 2018 at 22:29. Reason: accuracy clarification
sptsailing is offline   Reply With Quote
Old October 10th, 2018, 08:47   #17
petee_c
Fuel Economy: 5.68L/100km on my 1st tank; now averaging 5.4L/100km (Sept 2014)
good job.
I'm at about 184K miles and haven't looked at my cams yet.... bought it in 2014 with 90K miles on it...
my fuel mileage has stayed steady at about 42mpg, mostly rural driving at 60-70mph....
petee_c is offline   Reply With Quote
Old October 11th, 2018, 15:59   #18
Ol'Rattler
Ol'Rattler's Avatar
Originally Posted by petee_c View Post
good job.
I changed my cam at 88K miles when I did the T/B because when I checked the cam it had the tell tale copper streaking and one lobe was knife edged. My reasoning for changing it early was that with the wear just starting to show, I didn't need to drop the pan and replace the oil pump and also inspect the crank bearings for abnormal wear like some have had to do if they wait until a lifter is worn through.
Anything in the pan goes through the oil pump before it goes through the filter so it makes sense that if you have abnormal wear going on and fix it before there is a chance of metal getting into the oil, the oil pump will not be damaged and need to be replaced.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Wanted 2006 jetta mk5 dsg car-bad engine and/or bad trans SW US dtrvler TDI Cars for Sale/Wanted 0 December 10th, 2017 12:56
ALH cam break in plan scottw99 VW MKIV-A4 TDIs (VE and PD) 7 October 11th, 2017 02:43
This 2006 BRM OEM Cam with 196k looks pretty bad. lamboworld VW MKV-A5 Golf/Jettas 11 November 15th, 2014 13:16
2006.6 BRM Cam replacement 138K Advice /experience needed brianstrange VW MKV-A5 Golf/Jettas 5 December 3rd, 2012 09:14
2006 jetta tdi brm cylinder head and cam needed.... bostongsx Private TDI Items for Sale/Wanted 22 December 8th, 2011 09:13
Page generated in 0.14920 seconds with 13 queries
[Output: 62.22 Kb. compressed to 56.20 Kb. by saving 6.02 Kb. (9.67%)]
