Heated seat melted a hole right through to my leg
TurboTurtle
Canada
2004 tdi Jetta
Hello, i know this topic has been brought up before but i didn't seem to find anything recent. I purchased my 2004 tdi jetta in 2015 and the first winter i attempted to use the seat heaters and i noticed a horrible burning smell and turned off the seat heater. When i got out of my car i looked at the seat and there was a melted hole right where my leg had been (luckily it didn't burn me) when i bought my car the VW dealer mentioned the seat heater malfunction but told me mine had already been done...which is obviously not the case. I took my car to another local VW dealer and they told me the seat heater was never an actual recall and they cannot do anything for me due to the mileage on my car which is now over 410,000 km. Is there anything i can do or am i just stuck without a seat heater unless i feel like burning myself? Should i just get a used seat from somewhere or is it likely the problem will occur again?
Help is appreciated!:)
Nero Morg
OR
2014 A6 TDI, 2001 Jetta TDI, 2014 Passat TDI
As found in another post... Probably your best bet.
Just call VWGoA, give them your VIN #, they will tell you if recall was done. Also explain your problem. Suprisingly they sometimes will be on your side. 1-800-822-8987 Don't trust the dealer in what they say.
steve6
Beaverton, ON
2003 jetta tdi
A 2002/2003 or newer is needed due to the side impact air bags, but its an easy swap. Make sure the keys off when doing it or the airbag light will come on
Nero Morg
OR
You can swap out just the seat cover and cushion without unbolting the whole frame from the car, thus eliminating the need to mess with air bags.
STDOUBT
Portland, effing Oregon
dos jettas
Correct me if I'm wrong someone, but when replacing airbags (which is basically what you're doing when swapping seats) don't you need to turn them off with vcds, hook them up and then re-activate them again in vcds? Also, is it not standard practice to have the car's battery disconnected while un-hooking/hooking up the connectors?
Nero Morg
OR
Standard practice, yes, but not for our cars if you have VCDS. Turn off, swap, turn back on. Clear codes if present. In the manual it even says to disable with VagCom
Jnoelle
Minneapolis
Eos
Looking for advice, please!
My daughter’s 2012 Eos heated seat just burnt through the leather and her brand new winter coat! The holes are about a quarter sized. Will a dealer replace the seat and her coat? It’s obvi old, but her first car.
CanadianALH
Canada
2002 Jetta 5spd 2006 Jetta DSG (wifes)
Likely not. I tried to get mine done and they said no. Maybe call Vw customer service not the dealer but unlikely unless it’s an open recall.
