oilhammer
That sucks man. Sorry.
That sucks, I'm sorry to hear of your troubles. If you were anywhere close I would try and help you out.I have no choice, I have no other car, I can’t afford buying another car right now, I must learn how to remove the downpipe and turbo and any other parts in the way by referring to guides and kind advice and even actual in-real-life mechanical help from TDIclub forum members.
Step 1 is still to determine what is actually leaking. It might be a relatively easy fix still.
Both the above are true, you still need to find out for certain if it's the frost plug and even if you do locate it the probability is pretty high that all frost plugs are at about this same condition.Agreed... Get under the car and see what’s leaking.
Based on the color of your coolant, from another thread, I’d expect something else to start leaking soon. Even if you fix it, you’re on borrowed time.
-Todd
Any idea what size is these mk3 TDI freeze plugs?
Eleven available sizes from Advance Auto are:
1 1/8 inches
1 1/4
1 3/8
1 1/2
1 9/16
1 5/8
1 3/4
1 7/8
2
2 1/8
2 1/4
OK so looks like halfway between 1 3/8 and 1 1/2.They are 36.6 mm. The VW part number is 059 103 113.
I'm trying to make a plan of how to stick a cell phone camera in view of the expected blown out freeze plug (behind the turbo... the center freeze plug?).
Sadly I've actually been driving it but only very short distances 1-4 miles in town and low speed low RPM - weather this week is arctic air, around -5C (20F) with wind. I realize it's risky to overheat but sadly it's my only available choice so I'm extremely cautious to keep the RPM low and cause heat to build up in the engine only minimally. Need weather to be +5-10C (41-50F) so the snow and ice melts before getting on ground and spending time down underneath it getting more pictures and tearing it down. Also exploring mobile mechanic guys maybe one of them could do it for cheap enough I could afford...It's time to get motivated and start tearing it down. You've obviously found another mode of transportation.
You’d have to plug the oil supply to the turbo to even start the car. I occasionally do this to move a car 50 ft or so. It will no doubt go into limp mode.Question, Suppose I remove the turbo and then it becomes absolutely necessary to go somewhere with the car. Can the car drive with the turbo off? Obviously it'd be very loud with the exhaust wide open to the air and no back pressure, but apart from the loud exhaust noise, would the car drive?
In your shoes, I might get creative like maybe packing it with epoxy? Desperate times, desperate measures right?Sadly I've actually been driving it but only very short distances 1-4 miles in town and low speed low RPM - weather this week is arctic air, around -5C (20F) with wind.
Thanks for this epoxy tip, you’re right, epoxy’s low cost, and would hold, so it’s a good idea to get back on the road in my situation, as long as I’d carefully apply it. (I’d hate to clumsily dab it on there and get too much epoxy into the freeze plug hole, into the coolant jacket, and it block the flow of coolant.)In your shoes, I might get creative like maybe packing it with epoxy? Desperate times, desperate measures right?
Last year I fixed a home A/C condenser coil this way... it's holding like 160 psi still going lol.
Coulda used you yesterday.Since you're having to use coolant this time of the year when you drive it because water will freeze and ruin everything
Good luck. I hope you make out alright.as soon as the car thaws out this afternoon (coolant system is full of water so it’s frozen the temps now are 22F the water pump can’t turn !!)
Yes and it looks like this weekend is going to be another winner. We aren't getting more snow (fortunately) but the temps tomorrow night and into Sunday are going back down below zero (for lows) and single digits for highs.This thread keeps getting worse....
Cover the hood with a thick blanket, letting it drape to the ground. Drag out an extension cord and space heater. Keep it running...
I’d get it towed to the shop... hopefully you have AAA. I wouldn’t risk driving it, overheating and warping stuff.
-Todd
