Fix_Until_Broke
Well, the 1752 is on. Cost me an arm and a leg. Apparently the old turbo snapped its shaft at only half-throttle; it wasn't a WOT run. So, I had to pay for that cleanup, as well as a lot of custom fabrication.
However, the boost tube they fashioned up to go from the outlet to the intercooler isn't holding on. It blew off during a WOT run a couple of days ago. I just got underneath to confirm. They are using a ring clamp that doesn't seem to work, though it's a quality unit, and the tube is bent slightly off so it doesn't go on quite straight and true.
So, my question to all of you folks, where can I buy a hard rubber boost tube that is flexible enough to fit over the turbo outlet, in such a fashion that it will handle 28psi of boost without blowing off?
EDIT: A better question is, other than the correct type of ring clamp (they used the wrong one), is there a sealant of some sort that will work to help handle the boost?
BTW, the 1752 is AWESOME. Stock boost off the line, as responsive as stock, a lot more power mid and especially at the high range, where it just keeps making power. However, to fit it on your car at the least a custom intake will need to be made, as the entrace to the turbo from the airbox is on the passenger's side.
Pictures will help us help you fix the problems you're having.
