Ever since Monday this week my 96 Passat TDI has been being crabby in the morning... It just started getting colder, so I'm sure that has something to do with the issue.
When I first go to start it, I wait for the glow plugs to warm up and it starts up perfectly.
It runs great for about 5 seconds then stumbles to a stop. When I attempt to restart, I have to crank it over for almost a minute while feathering the throttle and it stumbles/creates a sizable cloud of smoke out of the tailpipe. Once I get the engine firing (roughly) at 1500 RPM or greater it runs beautifully again.
My initial thought was that I had bad glow plug(s) but that would not explain the perfect initial start.
After doing some research, I'm thinking I could have a pressure leak that is allowing fuel to bleed back into the tank thus leaving air in the lines. My pump does show signs of leaking around the underside, and I do have the stink of fresh diesel fuel under the hood.
Should I attempt replacing the fuel filter and plastic fitting on the top?
