Old June 19th, 2015, 14:25   #136
jokila
jokila's Avatar
Fuel Economy: 52/45/40
Since this thread is a lot about Prothe, why does this forum still let him post that he has parts or sale from his website in his sig as a non-vendor? He will randomly post (been awhile) leaving his sig to do the talking.
http://forums.tdiclub.com/member.php?u=87399
Ventecomy | Heated seat lighted switch | W8 light |
Blue tint aspherical tinted mirrors | Turn signal convenience | Euro Light Switch | Rear Fog Light | DrawTite Hitch | HIDs | 520 injectors | Engine Cover mod light |
VCDS-HEX/CAN & VagTacho available Houston metro area.
jokila is offline   Reply With Quote
Old June 19th, 2015, 14:26   #137
Good Ol' Boy
VeeDubTDI's Avatar
Have you clicked on the link in his signature? It redirects you to this thread.
Old June 19th, 2015, 14:30   #138
Abacus
That helpful B4 guy
Abacus's Avatar
Oh, that's good. Very good.
'97 B4: 453,000 miles Malone 3, PP520's, Stage 2 cam, SBC3, ARP studs, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR.
BUG*PWR 2013 Award Winner
Old June 19th, 2015, 15:13   #139
whitedog
That is almost too funny.
Old June 19th, 2015, 15:31   #140
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Fuel Economy: Great!
That is genius, Lawson!
-George Bernard Shaw
Old June 20th, 2015, 08:17   #141
jokila
jokila's Avatar
no. i didn't. I saw no need to go to his website. I guess that is better than removing it? ok.
Old June 20th, 2015, 09:36   #142
Good Ol' Boy
VeeDubTDI's Avatar
ok, indeed.
Old July 7th, 2015, 19:03   #143
quartersaw
Fuel Economy: Passat:44mpg Golf 52MPG
Default BEWARE of BLAAST Performance turbos ***BEWARE***
My BLAAST 'Billet turbo', which allegedly gave up to 30 lbs. of boost (per seller) lasted about 500 miles.
Had problems with the turbo from day one, and was fed a stream of B.S. by the seller.
BLAAST has ignored my e mails for warranty coverage.
I replaced it with a VNT-17, and have had no problems.
If you buy a BLAAST turbo, you are throwing away good money.
(I'm running a Malone Stage 4 tune)
quartersaw is offline   Reply With Quote
Old October 12th, 2015, 21:28   #144
BonosGlasses
Originally Posted by vwishndaetr View Post
Interesting. Though I am a pretty strict follower of "you get what you pay for" so I doubt I would buy anything excessively cheap, I am glad I ran into this. I've been on it for a few minutes following a link from VWVortex, and what he has to offer is inhumane.
Engineering? Jeeeeze.
As do I. I ordered injectors from this ass clown.
BonosGlasses is offline   Reply With Quote
Old October 13th, 2015, 14:40   #145
Good Ol' Boy
VeeDubTDI's Avatar
Cancel your order if you haven't received them yet.
Old October 20th, 2015, 04:08   #146
Drunken_Unicorn
Super glad that this community keeps an eye out for bad venders and keep everyone warned! I need to watch eBay buys more carefully.
'05 Jetta TDI AKA Dubya (like W)
2005 V10 Ford Excursion AKA Stan
Drunken_Unicorn is offline   Reply With Quote
Old November 13th, 2015, 09:02   #147
zukikat
Fuel Economy: 45mpg hwy
More than 4 years later this thread is still valid, and Prothe is still an actual ebay seller!
BEWARE!!!
zukikat is offline   Reply With Quote
Old November 13th, 2015, 23:04   #148
Nevada_TDI
Small parts that won't destroy a motor may be okay, but anything else is really suspect. If you do buy automotive anything through Amazon, Amazon gives a 365 day return basically no questions all above and beyond whatever the seller has listed in their ad.
Nevada_TDI is offline   Reply With Quote
Old January 30th, 2016, 18:03   #149
SuburbanTDI
*FORGERY WARNING*
Chinese Manufactured ALH/BEW/BRM Oil Pumps
Originally Posted by Franko6 View Post
Some time ago when reordering stock of oil pumps, we were sent some that didn't come in the same boxes that we were used to. The pumps appeared to have some manufacturing differences and worse, they were poorly made.
This first picture is not from excessive duration or trash that went through the pump. We took off a poorly hardened internals and after few thousand miles, this is what we saw...
The teeth of the pump were worn and pitted after short service. We removed the pump due to low oil pressure.
In order to spot these pumps, we have some pictures of the housing and especially, the gears, which are not made like the OEM pumps. First, a picture of a genuine pump.
the pump is distinguishable by the engraved 'Feintool' sprocket and the plastic alignment roll pins. Like it or not, the genuine roll pins are black plastic.
Here are some pics of oil pumps that are forgeries. The first is the sprocket, which is not only obviously heat treated, but the 'Feingold' labeling is laser etched rather than deeply stamped in the metal.
Here are some pics of the body of the the knock-off pump.
There are two other notable problems with the pump. On several of the pumps, the center lobe was cut off-center, so that the pump lobes struck each other at one point and had a .012" gap on the opposite side. Also, the sprocket bolt was little more than hand tight. The genuine pumps have the sprocket bolt assembled so tight that it takes some heat and persuasion to remove.
If you receive a pump like this, be forewarned, the quality is poor and may lead to the destruction of an engine. We have seen this same pump sold by our favorite CRAP distributor.
The complete thread on this pump can be found: HERE
SuburbanTDI is offline   Reply With Quote
Old January 30th, 2016, 18:51   #150
This thread is titled "Bad VW Part Vendor Warning List." Who's the vendor?
Vendor List TDIFest 2011 paramedick TDIFest 2011 20 September 2nd, 2011 21:04
Vendor List-where posted May-39 TDIFest 2008 5 August 5th, 2008 20:32
Vendor list brianteel TDI Power Enhancements 8 July 30th, 2006 09:26
Page generated in 0.17835 seconds with 11 queries
[Output: 133.53 Kb. compressed to 112.01 Kb. by saving 21.52 Kb. (16.12%)]
