[ QUOTE ]
I bet you're talking about the plastic belly pan, right? I just destroyed mine in a car wash, and will leave it off until the fall. At that time, I'm going to buy a steel skid plate to REALLY protect the car. IIRC the plast POS bellypan costs about $230 from the dealership, the Metal skidplate costs $350 or so.
[/ QUOTE ]Well, since he quoted a price for a pair of them, I am assuming it is the spalsh guards behind the tires. The belly pan is much more expensive. The cleaning caveat still applies.
[ QUOTE ]
Robin, you'll need to clarify whether you are speaking about the vehicle's belly pan (covers entire front underside of car) or the mud flaps that sit to the rear of the front (or rear) wheel openings.
I would use much discretion if you eliminate the belly pan. A few people are now finding that the belly pan helps protect the VNT turbo's actuator mechanism which will get jammed from flying debris. There is another thread going on this very topic.
It turns out that Garrett won't sell a new actuator mechanism which means the owner is going to purchase a new turbo. /images/graemlins/frown.gif
[/ QUOTE ]This is very true about the belly pan. It is not a skid plate, and won't protect against physical dmaage, but it seals pretty nicely on all four sides. It is designed to prevent water, dirt and foreign matter incursion intio the mechanical linkages (as described aboe) and all the sensitive electronics that cover this powerplant. It is highly inadvisable to run without this. Better yet, if you can afford the clearance, get a steel pan and never replace it again.
Mark
