afarfalla
owners manual says 4 qtrs., when I check the dipstick its a qtr. low so I add another to bring it to the fill mark
When I bought the car (05 Passat tdi GL) the previous owner addressed oil leaks by changing the pan and valve cover gaskets.
I changed the tandem pump gasket and all O-rings on the large metal hoses, this took care of all major leaks but one...
I have one leak coming from the inlet hose from the air box to the turbo, which includes the crankcase vent at the top of the valve cover. It leaks right at the turbo inlet (at the hose clamp) then drips down over the exhaust to the tranny then pools up on the ground.
The oil line to the turbo is just fine, the only place I see oil leaking is the hose clamp at the front of the turbo.
Could I possibly have to much oil?
Would I throw a code if the hose has a hole in it where its clamped to the turbo (casual look shows no holes or splits)
Is there a baffle system in the valve cover to prevent this? Maybe a part they left off when they changed the gasket?
