JFettig
Thanks mods! Could we give this thread back to the OP?
I did this once, and it was a big mistake....So, let a buddy of mine take the car for a drive.
first off, your tune shouldn't allow you to destroy your car, no matter what you do to it. I can floor my car from idle and it won't surge, over boost, or anything abnormal(lugging would be normal and of course isn't good for it).
Secondly, yes, most tuners can easily give you a very conservative tune that can be loaded with a flashing tool, by chips, etc.
If your car is allowed to surge, etc. You should get an updated tune.
Jon
Man, I'm not trying to offend you, but your logic is a little flawed.Dyno day, where at im down.
Also fwiw, my turbo also surges as well. At 70, if I floor it in 5th it'll surge some. At the moment keebler and I are concluding its due to the turbo. Someone with a 17/22 cant really compare since boost really isnt until 25-2800 rpm in our case.
I dont plan on any of my friends driving mine unless they understand driving cars with bigger turbo's.
Sent from my VM670 using Tapatalk
What I don't get is how come in the tunes for the bigger turbo, the fueling is not turned down enough below the point of surge?
Or are people running actuators that have weak springs or set too agressive?
I just say to my friends, you break you buy/fix or pay....
I have a gt2256v in my car as well, where I dont consider the actuator rod perfectly adjusted yet, and it's still just the first revision of the tune (which i would never say is perfect yet by any means)...you can't floor a 2256 until atleast 2,200 rpms =/
Hm. In 3rd gear my 30 to 60 MPH (48 km/h to 96 km/h) time is 4 seconds.Hi, I routinely see 335ds on the autobahn. With the twin turbos they are really moving. I once saw a report that the 335d was tuned by the big 3 Tuners in Germany to go from 286HP 580NM to about 340HP 690NM. They compared the elasticity measurement to a Porsche 911. i.e. 60-100kmh in 3.5secs. BMW has a big niche on the powerful diesels.
Scott, you live close enough, and we both have the same turbo. I'd be happy to take you for a ride in my car if you don't believe me. I believe you totally that your car doesn't surge, I just wished mine didn't . You have the same turbo as me so I'm sure it can be done I just need to get it worked out.I have a gt2256v in my car as well, where I dont consider the actuator rod perfectly adjusted yet, and it's still just the first revision of the tune (which i would never say is perfect yet by any means)...
All this being said, I have zero issues letting anyone drive it and floor it at any rpms. No surge, No spikes.
OK, but that was a 4th gear measurement.Hm. In 3rd gear my 30 to 60 MPH (48 km/h to 96 km/h) time is 4 seconds.
I see your point. The 911 was well out of its powerband (it would be in 1st and/or 2nd gear otherwise).OK, but that was a 4th gear measurement.
265 HP! That explains how the 335d I was following the other day handed me my derriere when we'd romp from 60 MPH to 80 or 90 MPH.Geez, I don't mean to hi-jack this thread, but I need to comment on this 335d. My understanding is, 44-93 mph, the 335d has no peer.
Here's the article:
http://www.thedieseldriver.com/2010/04/bmw-335d-three-month-test-report-and-review/2/
There, I'm done! :>) lol!
