VailPowder
RIP, Gone But Not Forgotten
- Joined
- Apr 15, 2000
- Location
- Vail, CO, USA
- TDI
- 2005 Jetta TDI Sedan, 1998 New Beetle TDI, 2004 Jetta TDI
For TDIclub members who also have a Cummins
Special price $649 with Free Retainer [ $45 value ] and Free shipping
Cummins 5.9L Cams
Colt Cams is proud to introduce our latest grinds for the Cummins 5.9L B series engine! We've worked long and hard to develop these great new profiles. We've dyno'ed some 50 different combinations of durations, lobe separation and installed centerlines to come up with the ultimate cam for your Cummins 5.9. We have a large quantity of new cast billets in stock ready for you! Our 5.9L Cummins cams are available in 6 stages. We are always willing to customize alternative grinds as well.
Stage 1: The best grind for fuel economy and bottom end torque!
Benefits of Colt Cams High Performance Cummins Diesel Camshafts
Remember it’s far cheaper to do it right the first time so buy from the original manufacturer of Cummins High Performance Diesel Camshafts Colt Cams.
Here are the benefits you will see from Colt Cams "The Big Stick" High Performance Cummins Diesel Camshaft
* Higher Lift
* More aggressive ramp rates
* More duration
* Lower Exhaust GasTemperatures of 100 - 250 degrees
* Faster Turbo spooling 100 – 200 rpm sooner
* Bolt on option
* Fuel Economy improvements of 1 - 3 mpg
* Major reduction in smoke
The Unique Features of the Colt Cam "The Big Stick" High Performance Cummins Diesel Camshaft:
* 1.020” wide lobes (widest in the aftermarket)
* Thicker core
* Radiused core
* Every cam is drilled and tapped for a bolt on retainer
* The ONLY improved design cast cam on the market
* Cold Chilled Billet Iron Blank insures durability
Cummins 5.9L Cams
- Straight drop in
- No clearance issues or springs required
- Lobe separation, higher lift and longer duration, improves air flow by approximately 30%
- Reduces turbo lag, faster spool up
- Greatly improved throttle response
- Approximately 25% reduction in smoke
- 100 – 150° EGT drop
- 1 – 3 MPG increased fuel economy on average
- RPM: Idle – 2700
- Write-up in Diesel Power Magazine
- RPM: Idle – 3000
- Average 2 – 3 MPG increase
- 30 – 35 % smoke decrease
- Approximately 200° EGT drop
- Good to 4000 rpm
* Higher Lift
* More duration
* Bolt on option
* Thicker core
* Radiused core
