Dieselmunkey
Hello all, i've had nearly nothing but VW's for the last 13 years or so, finally time to start pumping power into my ALH. So, to begin:
2000 ALH, 275k or so miles. Owned this car for maybe a year and a half now. Fresh timing belt, idlers, water pump, etc. 2 months ago. So i started getting a few things together. Made an OMI, 2" piping to stock SMIC. EGR deleted, PD 150 manifold. Making a 2.5" DP now. muffler gone. So currently i just uploaded my new Kerma tune, and installed fresh calibrated PP764's. New VNT17 w/ 3-bar map, proper oil feed, return are probly due to my door toward the end of the week. Issue is, the clutch is already slipping so the only other mods i plan at this time that i haven't bought yet will be an 11mm pump, upgrading SMIC to a better Kerma SMIC. and likely doing 3" DP and larger full exhaust. Possibly a Colt stage 2 cam if my buddy goes thru with his upgrade.
So i'm curious since i'm sure there's hundreds of other cars running the same stuff i am. Anyone have any idea what kind of torque i'm doing after the VNT-17 and re-tune go in? then what i'll see after the 11mm? I'm shopping for clutches, but have no idea how much i want to account for. I'm likely to try to stick with SBC, but that's why i'm here. Car currently has what i believe to me a SMF with VR disc. chatters pretty good at idle. but i'm not going to pull the trans just to look at part numbers.
Also, i'm mostly running highway to work daily. But get stuck in traffic jams frequently. so i'm trying to stay away from a brick of a pedal. Thanks in advance, your experiences will be very helpful
