Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old February 20th, 2018, 23:11   #1
pkhoury
That guy with the goats
pkhoury's Avatar
Fuel Economy: CR - 36-41, PD - 39-48 (26-32 while towing)
Default BCM possibly gone bad?
I've been having some issues, namely after I got my Westphalia trailer controller installed. First issue, which was minor, was my rear fogs stopped working. The bulb itself is good, but I had a bulb out light on the instrument cluster and a message saying the rear fog light was out. Actually, what's weird is that a few times, the error and bulb out light would go out, and even if I activated rear fogs (which still didn't work), I didn't get the error.
Next problem is the error would come up with the warning tone more frequently while driving, taking me away from PolarFIS to show me the message that the rear fog light is out.
Lately, that's also been accompanied by my door locks randomly unlocking while driving at highway speeds. If I slowed down for a light or traffic, and then got above 15mph, the door locks would engage, and then disengage at some random speed and interval. HVAC also stopped working; about two weeks ago, it stopped working for about 10 minutes, and then magically engaged the compressor and worked beautifully.
It stopped working today for about 8 minutes, worked great, and then stopped later in the evening on my way back home. When I went to check VCDS, I found a bunch of errors.
Code:
Tuesday,20,February,2018,23:40:59:38941
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 17.8.1.0 (x64)
Data version: 20171130 DS276.6
www.Ross-Tech.com
VIN: 3VWTL7AJ0AM681213   License Plate: NOTADEM
Mileage: 336550km-209122mi   Repair Order:
Chassis Type: AJ-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 4F 52 56 62 65 69
72 77
VIN: 3VWTL7AJ0AM681213   Mileage: 336550km-209122miles
01-Engine -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
65-Tire Pressure -- Status: Malfunction 0010
69-Trailer -- Status: Malfunction 0010
Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
Part No SW: 03L 906 019 CM    HW: 03L 906 022 TS
Component: R4 2,0L EDC G000AG  9971
Revision: 12H14---    Serial number: 00000000000000
Coding: 0050078
Shop #: WSC 91750 042 00000
VCID: 78FF835D0B4B5686A9-802C
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans        Labels: 02E-927-770.clb
Part No SW: 02E 300 052 T    HW: 02E 927 770 AL
Component: GSG DSG AG6     511 2114
Revision:    51112    Serial number: 00001002230234
Coding: 0000024
Shop #: WSC 01286 386 08256
VCID: 25419A29EC791B6EC2-8070
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
Component: ESP MK60EC1   H30 0107
Revision: 00H30001
Coding: 114B600C492A00FB880D06E5921C0042310000
Shop #: WSC 00066 000 00000
VCID: 7AFB9955F5474496DF-802E
Address 08: Auto HVAC (J301)       Labels:| 3C8-907-336.clb
Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
Component: Climatic      H14 0305
Revision: 00009001
Coding: 0000001002
Shop #: WSC 00066 000 00149
ASAM Dataset: EV_Climatic A01005
ROD: EV_ClimaBasis_VW36.rod
VCID: 75E18A69D4592BEEB2-8020
4 Faults Found:
13701408 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 254
Reset counter: 72
13701936 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 54
Mileage: 325965 km
Date: 2017.12.14
Time: 18:54:35
13701456 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Reset counter: 72
9479697 - Control Circuit for Front Left Seat Heater
B10A6 11 [008] - Short to Ground
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 27
Mileage: 336155 km
Date: 2018.02.07
Time: 12:55:22
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 085 G    HW: 5K0 937 085 G
Component: BCM PQ35 B++  111 0129
Revision: BI111001
Coding: 2D380E3C803F3EC480080081400000840100028653518560648020000000
Shop #: WSC 00066 123 12345
VCID: 377D406186D599FE60-8062
Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
Component: Wischer 09041  21  0512
Coding: 009795
11 Faults Found:
00526 - Brake Light Switch (F)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 119
Reset counter: 72
Time Indication: 0
Freeze Frame:
Term 15 On
Voltage: 13.70 V
ON
ON
OFF
OFF
ON
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Reset counter: 72
Time Indication: 0
Freeze Frame:
Term 15 On
Voltage: 9.75 V
OFF
ON
ON
OFF
OFF
01299 - Diagnostic Interface for Data Bus (J533)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 70
Time Indication: 0
Freeze Frame:
Term 15 Off
Voltage: 12.20 V
OFF
OFF
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 6
Reset counter: 72
Time Indication: 0
Freeze Frame:
Term 15 Off
Voltage: 12.30 V
OFF
OFF
OFF
OFF
OFF
01309 - Power Steering Control Module (J500)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 136
Reset counter: 72
Time Indication: 0
Freeze Frame:
Term 15 On
Voltage: 13.60 V
ON
ON
OFF
OFF
OFF
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 6
Reset counter: 72
Time Indication: 0
Freeze Frame:
Term 15 On
Voltage: 11.40 V
ON
ON
OFF
OFF
OFF
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 6
Reset counter: 72
Time Indication: 0
Freeze Frame:
Term 15 On
Voltage: 11.40 V
ON
ON
OFF
OFF
OFF
01321 - Control Module for Airbags (J234)
Freeze Frame:
Fault Priority: 6
Reset counter: 72
Time Indication: 0
Freeze Frame:
Term 15 On
Voltage: 11.40 V
ON
ON
OFF
OFF
OFF
01502 - Bulb for Rear Fog; Left (L46)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 19
Reset counter: 19
Mileage: 325502 km
Time Indication: 0
Date: 2017.12.10
Time: 16:20:37
Freeze Frame:
Term 15 On
Voltage: 11.70 V
ON
ON
OFF
OFF
ON
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 5
Fault Frequency: 7
Reset counter: 54
Mileage: 325965 km
Time Indication: 0
Date: 2017.12.14
Time: 18:54:31
Freeze Frame:
Term 15 On
Voltage: 13.30 V
ON
ON
OFF
OFF
ON
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 5
Fault Frequency: 10
Reset counter: 54
Time Indication: 0
Freeze Frame:
Term 15 Off
Voltage: 12.40 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
Component: AirbagVW10G   021 0706
Serial number: 003C4D0AKTKP
Coding: 00003044
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 39794659B8C18F8E96-806C
Seat occupied recognition:
Subsystem 1 - Part No SW: 1KM 959 339     HW: 1KM 959 339
Component: BF-Gewichtss.  007 0001
Serial number: ---0000R--00056TVD00
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
Component: S.Sens.Fahr.V  H01 ----
Serial number: 3572MSME0061624FZZZR
Crash sensor for side airbag: front passenger side:
Subsystem 3 - Part No SW: 1KM 955 557     HW: 1KM 955 557
Component: S.Sens.Beif.V  H01 ----
Serial number: 3582MSME7B40604FZZZ+
Crash sensor for side airbag: rear: driver side:
Component: S.Sens.Fahr.H  --- ----
Serial number: 3511HSME072D761FZZZW
Crash sensor for side airbag: rear: passenger side:
Component: S.Sens.Beif.H  --- ----
Serial number: 3521HSME3219761FZZZQ
Crash sensor for front airbag: driver side:
Component: F.Sens.Fahr  --- ----
Serial number: 35527SME70057420ZZZ1
Crash sensor for front airbag: front passenger side:
Component: F.Sens.Beif  --- ----
Serial number: 35627SME441A7420ZZZ9
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
Component: J0527           056 0111
Coding: 0001832
VCID: 76E38D65015F20F6BB-8022
Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS   H05 0010
Coding: 00000130
Shop #: WSC 00000
1 Fault Found:
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
Part No SW: 5K0 920 970 Q    HW: 5K0 920 970 Q
Component: KOMBI         H13 0112
Revision: X0013004    Serial number:
Coding: 270D00
ASAM Dataset: EV_KombiUDSMM9RM10 A04102
ROD: EV_KombiUDSMM9RM10_A04_VW32.rod
VCID: 3C775F4DB7F3BAA68D-8068
1 Fault Found:
13631488 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Reset counter: 72
Mileage: 335700 km
Date: 2018.01.28
Time: 14:17:33
Address 19: CAN Gateway        Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AE    HW: 1K0 907 951
Component: J533  Gateway   H06 0112
Revision:   H06 01    Serial number: 220310F1001000
Coding: ED807F47400603002002
VCID: 6ADBA91545E7F4162F-803E
1 Fault Found:
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 72
Mileage: 336491 km
Time Indication: 0
Date: 2018.02.20
Time: 19:30:47
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234     HW: 5K0 920 970 Q
Component: IMMO          H13 0112
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ImmoUDSMM9RM10 A01102
ROD: EV_ImmoUDSMM9RM10_VW21.rod
VCID: 6ADBA9158DE7F4162F-803E
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
Part No SW: 3C0 035 684 D    HW: 3C0 035 684 D
Component: RNS-MID       H12 1140
Revision: AB001001    Serial number: VWZ6Z7L5173028
Coding: 0C0004000400009000
Shop #: WSC 22142 444 59205
VCID: 2447872D2743E266D5-8070
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 -  -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Reset counter: 32
Mileage: 324784 km
Time Indication: 0
Address 42: Door Elect, Driver (J386)       Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 701 B    HW: 3C0 959 793
Component: TUER-SG FT    002 0307
Revision: 13101005    Serial number: 0000637923
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide.rod
VCID: 275D90215E75097EF0-8072
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T  Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL  006 1401
Serial number: 00000004784947
Coding: 000490
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70     3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 31697E79A8B147CE2E-8064
Address 4F: Centr. Electr. II (J520)       Labels:. 1K0-907-532.clb
Part No SW: 1K0 907 532     HW: 1K0 907 951
Component: EZE_2         H06 0112
Coding: 050B0500
VCID: 66C3DD2591FFD0760B-8032
Subsystem 1 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
Component: J245EE20SKB13  H01 0220
Serial number: 0123456789ABCDEFGHIJ
Subsystem 2 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
Component: J394EE20SKB13  H01 0220
Address 52: Door Elect, Pass. (J387)       Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 702 B    HW: 3C0 959 792
Component: TUER-SG BT    002 0307
Revision: 15101005    Serial number: 0000646639
Coding: 0004B4
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide.rod
VCID: 285F931D536B0606F9-807C
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T  Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR  006 1401
Serial number: 00000004773329
Coding: 000490
3 Faults Found:
68102 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Reset counter: 72
68103 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Reset counter: 72
68107 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Reset counter: 72
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
1 Fault Found:
000 -  -
Freeze Frame:
Fault Priority: 7
Reset counter: 32
Mileage: 324784 km
Time Indication: 0
Address 65: Tire Pressure (J502)       Labels:. 1K0-937-08x-65.clb
Component: RDK           111 0821
Coding: 018705
1 Fault Found:
02903 - Hard Warning 2
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 333666 km
Time Indication: 0
Date: 2018.01.14
Time: 17:29:26
Freeze Frame:
Text: 3444468620
Pressure: 1.90 bar
Pressure: 2.40 bar
Temperature: 36.0C
Text: C0
Speed: 52.0 km/h
Address 69: Trailer
Cannot be reached
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 F    HW: 7P6 035 730 F
Component: TELEFON       H09 2902
Revision: 1B001001    Serial number: 00007660693870
Coding: 0A10000000010100
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 35614A6994D96BEE72-8060
What's weird, is I wasn't able to connect to Address 09 (Central Electronics). But just trying to access it, I can no longer see it when doing scans.
Code:
Wednesday,21,February,2018,00:03:49:38941
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
Mileage: 336550km-209122ami   Repair Order:
72 77
Coding: 0050078
VCID: 78FF835D0B4B568420-802C
Coding: 0000024
VCID: 25419A29EC791B6C4B-8070
Revision: 00H30001
VCID: 7AFB9955F547449456-802E
Cannot be reached
Cannot be reached
Unable to communicate with address 09. Are you sure the doors are unlocked?
Coding: 00003044
VCID: 39794659B8C18F8C1F-806C
Cannot be reached
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
Coding: 270D00
ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
VCID: 3C775F4DB7F3BAA404-8068
1 Fault Found:
U1111 00 [008] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 6
Reset counter: 72
Mileage: 335700 km
Date: 2018.01.28
Time: 14:17:33
VCID: 6ADBA91545E7F414A6-803E
Coding: 000000
ROD: EV_ImmoUDSMM9RM10_VW12.rod
VCID: 6ADBA9158DE7F414A6-803E
VCID: 2447872D2743E2645C-8070
1 Fault Found:
000 -  -
Freeze Frame:
Fault Priority: 7
Reset counter: 32
Mileage: 324784 km
Time Indication: 0
Cannot be reached
Revision: 00H17000
VCID: 31697E79A8B147CCA7-8064
Address 46: Central Conv.
Cannot be reached
Coding: 050B0500
VCID: 66C3DD2591FFD07482-8032
Cannot be reached
1 Fault Found:
000 -  -
Freeze Frame:
Fault Priority: 7
Reset counter: 32
Mileage: 324784 km
Time Indication: 0
Address 62: Door, Rear Left
Cannot be reached
Cannot be reached
Address 69: Trailer
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
ROD: UHVNA.rod
VCID: 35614A6994D96BECFB-8060
End-------------------------(Elapsed Time: 03:14)--------------------------
Address 56: DTCs cleared
Address 17: DTCs cleared
Now I'm wondering if I bricked my BCM. The car still starts up, of course. I can talk to ABS, DSG, ECU and some other controllers, but obviously none of the items in which it shows an error.
If anyone has any suggestions, it would be much appreciated. I haven't tried pulling the battery, and I'm not sure what fuses to pull (although I've thought of checking fuses to make sure none have blown).
2010 Jetta Sportwagen - Malone DSG tune, Malone Stage 3.5, CR170, buzzken 3" straight pipe(resonator deleted), PolarFIS, Panzer plate, front and rear fogs, Bosal towhitch, Bilstein B8/Neuspeed 28mm swaybar, 2micron CP3 upgrade kit
2004 Golf GLS 5MT -
Malone Stage 4, VNT17, DC Stage 2 clutch, buzzken 2.5" straight pipe, MFA cluster swap, dieselgeek Panzer plate and short shifter, Bosal towbar, Tekonsha P3 brake controller, Hopkins short-proof trailer light converter, darkside SMIC, intake manifold, and tip pipe, PD150 airbox
2005 Jetta Wagon GLS (mom's car) - Malone Stage 4, VNT17, MFA cluster swap, Panzer Plate, buzzken 2.5" straight pipe, darkside SMIC
2015 Golf Sportwagen TDI (mom's car) - stock for now...
Other diesels:
Ford 5900 tractor
Ford 3400 Industrial tractor
2016 Mahindra XTV (1L Kohler diesel)
pkhoury is offline   Reply With Quote
Old February 21st, 2018, 03:36   #2
Tdijarhead
Try disconnecting the trailer controller.
Weird electrical issues are often caused by low battery voltage or aftermarket equipment.
Tdijarhead is online now   Reply With Quote
Old February 21st, 2018, 05:38   #3
pkhoury
pkhoury's Avatar
I'll try measuring the battery's voltage. The trailer module isn't easy to get to. I'd either have to disassemble most of the rear driver's side, or access the BCM. And, I might have potentially figured out my problem - Byte 18 on my BCM/CCV is different from the factory 00, after doing more research (and falling asleep at the computer while doing it).
2004 Golf GLS 5MT -
Other diesels:
Ford 5900 tractor
Old February 21st, 2018, 09:30   #4
turbobrick240
turbobrick240's Avatar
The brake controller might also not be playing nice with the Polar FIS. I'd try disconnecting whichever one is easier to get at.
Old February 21st, 2018, 11:22   #5
pkhoury
pkhoury's Avatar
I haven't had any problems with PolarFIS to be honest, and PolarFIS connects via the bluetooth menu (which is accessible through Telephone, which should be module 77).
I'm starting to think the problem might be with the BCM itself, so I found an exact part number used part on ebay (that subsequently came out of another 2010). I'm honestly thinking that the coding change on Byte 18 conflicts with the trailer (as the external lighting was set for RoW and the trailer set for North America).
2004 Golf GLS 5MT -
Other diesels:
Ford 5900 tractor
Old February 21st, 2018, 11:50   #6
turbobrick240
It might be the bcm, but the Autopolar unit connects through the CAN gateway, and has caused similar issues for some people- usually when it's used in conjunction with other aftermarket electronic devices. I'd try disconnecting the controller/Polar before buying a new bcm.
Old February 22nd, 2018, 00:52   #7
pkhoury
pkhoury's Avatar
I'll try that and see if that changes things, although I now probably won't get around to it until I finish doing injectors and glow plugs on the truck. I'll keep the thread updated on my progress.
2004 Golf GLS 5MT -
Other diesels:
Ford 5900 tractor
Old February 24th, 2018, 15:36   #8
pkhoury
pkhoury's Avatar
Fixed my problem. What was it? Bad BCM. I wanted to be safe and ordered one on ebay. Arrived today (because somehow, San Antonio thought it should go to a post office 90 miles away). AC blows pretty damn cold, and I can access all my modules. Time now for the test drive. So now I know for the future - no more messing around with Byte 18!
Oh, and PolarFIS still works flawlessly.
2004 Golf GLS 5MT -
Other diesels:
Ford 5900 tractor
Old February 24th, 2018, 15:50   #9
pkhoury
pkhoury's Avatar
Just finished a spirited test drive. Now that the steering angle sensor LED and TPMS LED is off, car works great, AC works beautifully, and no more errors. The old BCM is officially bricked.
2004 Golf GLS 5MT -
Other diesels:
Ford 5900 tractor
BCM differences jjcsnlynn VW MKIV-A4 TDIs (VE and PD) 2 June 4th, 2017 20:05
Fog lights and interior lights not working. Bad BCM? BarrieCommuter VW MKVI-A6 Jetta Sedan (~ 2011+) 1 August 17th, 2014 10:35
BCM Module powerstroker363 VW Passat Family (NMS and B7) TDIs (2012+) 9 September 26th, 2013 06:52
HELP! My TDI runs really bad. Several DTC's - Possibly Bad ECU? DJGonzo TDI Power Enhancements 11 April 2nd, 2010 19:30
Maf sensor possibly bad, will 2.0 gas work on 1.9 ptsbug TDI 101 6 April 12th, 2005 11:23
Page generated in 0.17550 seconds with 13 queries
[Output: 136.67 Kb. compressed to 116.11 Kb. by saving 20.56 Kb. (15.05%)]
