mposey519
So what's the difference/Benefit between buying/renting the tune flashing hardware and doing it yourself and having a tuning dealer do it for you?
For one thing ... the direction that the finger points if something goes wrong!So what's the difference/Benefit between buying/renting the tune flashing hardware and doing it yourself and having a tuning dealer do it for you?
As best I have been able to tell, everything is stock on the Golf. I'll not be tinkering much(so I say now...a week into ownership,,,we'll see).It also can depend on what other, if any, mods you may have. If the car is otherwise totally stock (and healthy), a standard map of the 'off-the-menu' variety is perfectly adequate.
But if you've done a bunch of other things, then maybe something a bit more tailored to your car is needed to make best use of the whole package. In this case, someone who knows what they are doing with the software changes can be advantageous.
I also myself like to be certain the car is in good order otherwise, first. Lots of people come in our shop wanting more power and think a software change (or "chips" to use the outdated term) is what is needed, when in fact the last clown that did the M&P timing belt job has the pump timing so far off the graph the car runs like crap. And it'll run like crap tuned, too.
..., but will probably have Skunkwerx check it over first.
