New Mexico TDi
So we had the 40K service done about 2 weeks ago, and since then the fans run after just about every shutdown. Took it in to the dealer (PITA as they are 80 mile away), and they are telling me the coolant temp senor is bad. I have some questions, they tell me it spit a code for the coolant temp, but the gauge was fine, rock solid at 190, and I have never gotten a MIL. I'm guessing the sensor must have 2 thermocouples inside as I understand that it feeds the ECU and the gauge, it was feeding a signal indicating 210 degrees to the ECU, which is what was causing the fan to run. Makes me wonder if the 210 is correct, indicating a bad thermostat, so wondering if I should have that swapped at the same time? I have a lifetime engine and power train warranty from the dealer as long as I bring it to them for service, kills me as I normally don't trust dealerships to work on my vehicles. I appreciate any TDi specific info I can get.
Dave
Dave
