mrspindlelegs
I've searched the forums and didn't find the answer I was looking for (yet).
I'm nearing the end of installing the KermaTDI 150 HP kit on a 2004 Golf TDI (BEW engine). I'm using the modified BV 39 turbo (Series 7). The kit claims to be "turn key" but I'm finding that it is "close but not quite". The problem is that the flexible hose that goes between the turbo and the pancake pipe does not fit. The fitting on the turbo end did have to be rotated but even after getting tabs set, it looks like there is no way the OEM hose will work (will be kinked/pinched nearly shut and be prone to rubbing against the engine or frame).
Has anybody else run into this? Did you have to fabricate the hose yourself to get this kit to work?
