AntonUK
Sorry for the quality I took them on my phone camera....is that a wastegate steve....havnt you heard there crap?
I think its the one for the wrx sti scooby .hatemi said:May I ask where that intake manifoild is originally from? It's frigging huge
Nice pipe work there. What ID are those intake and charge pipes?
You lost me............mojogoes said:Its in hand.
Very cool on the valve cover. Guess I phrased it wrong. Not that its just for looks, but someone on the aftermarket making a cast aluminum valve cover would be cool. I had a Polo G40 one on my IDI TD and sold it with that. Anyways...the chrome one on yours dresses things up...looks nicemojogoes said:Yes its the same one , it will be interesting to see how different the motor runs and behaves with the electronic pump plus charge air cooling which is a. t. a. instead of a. t. w.
If i remember its also had a cut back to increase flow even further so that is another thing to judge against the last setup of the T25 , which i must add is held high up there in my eyes , and because this engine has had a slight capacity change.............and also air flow improvements another aspect to look at would be the off boost power/pickup and driveability.
The valve cover was £45 to be electro plated.
what exacty was the mod if you don't mind me asking.mojogoes said:yes..
Hmmmm. ss manifold?mojogoes said:Its a ss manifold/header with an extended u shaped header to place the turbo over the gearbox so as to give it the room to fit , it also makes more room for a larger straighter up/down pipe .
I will ask Anton to put some more pictures up for me next time.
#somepunk22 said:Hmmmm. ss manifold?
}mojogoes said:Home made/home made!!!..................REALY
