Hello TDI Club, I came to this website when my grandfather let me have one of his old jettas with the 1.8 TDI in it. I’m a seventeen year old just wanting to wrench away and get a reliable, fuel efficient diesel for college. It has many issues like rust, bad smell, a boot lid that won’t shut, etc., but I came for my engine. When we first got it, the alternator was not charging, but is now. I can only assume that the brushes were dirty. The big problem is oil consumption. We saw that it was spitting oil from the vacuum pump, the turbo actuator was replaced, the EGR valve had oil residue on it, and the hose that connects the CCV valve to the intake was duck taped together. We replaced all of this, and when I go and moved it to another spot so that I can see if there is an oil leak. Sure enough, after I put oil in it, oil was on the ground and what looked like coolant too that next afternoon. It seemed to be leaking from the passenger side of the engine, where all of the pulleys and tensioners are. I’m just wondering if there is potentially a cracked block, or maybe a crankcase seal went bad? I’d just love some suggestions!
Thanks for the help,
-Benjamin
-Benjamin
