garciapiano
Hey guys,
I’ve noticed on hot days that the fans will run for a few minutes after shutting off the car. This has happened in several instances regardless of how hard I was driving the car, It appears to be a built in feature since the fans do eventually shut themselves off, although I don’t know what would be the benefit other than cooling the engine compartment. There is no after-run coolant pump. Is it normal and what are the conditions under which it will occur?
