I had the blend doors done last year and at that time I noticed the 2 end vents were not blowing ac out as strong as the 2 center vents which are about even now after the blend door fix.
the 2 end vents have gotten worse. The compressor and expansion valve replaced in 2019.
shouldn't all 4 vents be blowing the same? I am original owner and do not remember uneven air flow...some tdi owners have told me that they have the same problem.
any ideas for fixes? This issue is same when I turn heat on.
