pakhribas
2002 Jetta, Quick question. While getting the car ready for winter, I pulled the slider pins from the rear brake to re-lube them with anti-seize. Pulled both out...cleaned them....then noticed that the pins are different. One pin has a flat side...the other is round. Which pin goes in the top/bottom?
