chapelhill
Engine: 2.5tdi 5cyl (1996 Volvo 850) 11mm pump Race520 Nozzles (Upgrade from standard 502’s) KKK14 waste gate turbo, mild porting to head and turbo waste gate. (Dual mass flywheel). 155k miles and was well maintained until the water pump failed taking out the cam belt. I have rebuilt with new exhaust valves and followers and everything else seems fine.
Vibration sounds like going over rumble strips at side of motorway, but not quite as harsh.
Vibration occurs with standard ecu and modified ecu.
Vibration starts at about 1800 rpm, with more than 70% throttle by which time there is only about 11psi of boost and no smoke. Less throttle and the engine is perfectly smooth. The vibration completely disappears after 2600rpm.
I have tried running the modified ecu with losts of extra fuelling in my good lady’s identical standard car and power is smooth at all rpms.
Vibration cannot be felt during WOT accel in 1st or 2nd and only just be detected in third. In fourth and fifth it is very obvious.
As the only real change from standard is the Nozzles from 502’s to race520’s, any ideas of what needs to be modified to iron this out? I have searched the forum and seen only couple of similar problems, but no resolution.
My thoughts were that for vibration we need somewhere to store energy, which would probably we the dual mass flywheel, and the excitation force being the higher cylinder pressure being produced before TDC by the larger nozzles. If this is so can the ecu be reprogrammed to retard the start of injection angle for this range, and if so what would a good value to try be, say 3 degrees? What sort of advance would be standard under these conditions?
Many thanks in anticipation.
Chapelhill.
Chapelhill.
