Denali376
- Joined
- Feb 4, 2020
- Location
- Lucedale,Mississippi
- TDI
- 06 Jetta tdi BRM 5 Speed, 06 vw Jetta tdi brm DSG
06 VW Jetta BRM, POS!
Manual 5-speed
It ran before I removed the engine/transmission but 1&4 where low on compression. Removed the cylinder head and Ceramic glowplugs broke into small shrapnel. Caught in the rings, cylinder walls scarred up.
Overbore .25mm Glyco bearings throughout ARL pistons, TOTAL SEAL modified Gapless Goetze rings. Balanced rotating assembly. Should be a solid engine.
After getting everything back together I am now dealing with a no start issue. The ignition functions as far as key on engine off. When I try to start the engine the starter doesn't engage. I have jumped the starter posts and the starter spins over. I'm going to check the starter relay today. When I turn the key on engine off position the cooling fans come on and run every time. I have checked under hood fuses.
Any ideas?
Manual 5-speed
Any ideas?
