Old April 22nd, 2020, 13:37   #1
BlueOnBlack
BlueOnBlack's Avatar
Default Buzzken install
Has anyone installed a buzzken delete kit? Iím not sure if Iím missing parts or something but it seems like I might be. Thanks
BlueOnBlack is offline   Reply With Quote
Old April 23rd, 2020, 08:51   #2
740GLE
What'd you order? Did you get a resonator and a cat?
post up a pick.
Hers: 2015 Passat SEL (NOS) w/ VW fix and Malone Stage 2 (low torque for DMF shudder).
Old April 25th, 2020, 21:16   #3
joshferrer
joshferrer's Avatar
Same question for me, what did you order?
I have the Rawtek delete on my car. I assume it would be similar?
-2014 Passat TDI SEL
Malone Stage 2 "Econo" Tune.
Rawtek DPF, EGR, DEF Delete Performance Kit. Straight Pipe. No resonator and no cat.
joshferrer is offline   Reply With Quote
Old April 26th, 2020, 18:11   #4
BRIAN427COBRA
So in my research the Buzzken kit seems to be a little short on things needed, like the cooling bypass kit that Rawtek includes, also actual instructions.
If You Don't Have a Panzer SkidPlate, Get One ASAP
BRIAN427COBRA is offline   Reply With Quote
Old May 6th, 2020, 05:14   #5
BlueOnBlack
I’ll post some pics later. I ended up finding a piece of hose and made it work. Had to make a bracket for the metal coolant pipe too. As far as the exhaust it fit perfect and the tune from Malone is definitely an upgrade. Mpg is up I haven’t hand calculated yet but I will. No resonator no cat just the factory muffler. It’s quiet. In the car with windows up it is silent.
Old May 7th, 2020, 13:57   #6
AaronB
Which tune did you go with
AaronB is offline   Reply With Quote
Old May 12th, 2020, 07:58   #7
glester
The kit for the 2015 is different than those for the previous years in that series, right? I have a 2013 Passat Tdi M6 and have the kit ready to be installed. I'm curious how much time it took for you and others to complete. Anybody have advice on things that might have not been straightforward?
Thanks in advance!
glester is offline   Reply With Quote
Old May 13th, 2020, 11:55   #8
Lex Tdi
TDI(s): 2013 Passat
Hate to hijack but i just got my passat back today with my rawtek installed. Did you all move back to just regular diesel oil? Like a rotella from the old A4 days? I have a few more changes with total quartz 507 but just for future reference...
2013- Passat SE DSG 190,000 miles
RIP 2003 Jetta - 444,000 miles
SOLD 2001 Jetta - 300,000 miles
Thanks to Paramedick (Bruce) for being my local Guru for over a decade!
Lex Tdi is offline   Reply With Quote
Old May 15th, 2020, 16:39   #9
turbodiesellover
Fuel Economy: 42-48 Highway
I
Iím using Mobil 1 TDT 5W-40. After extensive research I determined this is the oil I should use.
My reasons are the Mobil 1 TDT is thinner at operating temp (100C) than other (Rotella, Delo, Valvoline 5W-40). It is pretty close to the 507 spec viscosity. The 5W-30 is on the thick side of 5W-30 at operating temp. (And Mobil 1 TDT is on the thin side of 5W-40.
Other reason is the Mobil 1 TDT has a lot of Zinc, and Phosporus compared to other brands of oil. You can see this on Mobilís website.
It is readily available at Wal-Mart and like $24 per gallon, came out to $14 with rebate recently.
Mobil Delvac ESP 5W-40 was my second choice. I couldnít find the zinc and phosporus levels, and it is another $12 per gallon.
I have a some Mobil ESP 5w-30 (507 Oil) left over and will run this in the winter. Iíll do some oil analysis on these oils too.
turbodiesellover is offline   Reply With Quote
Old May 18th, 2020, 11:19   #10
Lex Tdi
TDI(s): 2013 Passat
Appreciate the input.... thank you!
Old May 21st, 2020, 12:27   #11
TheMysticWizard
I didn't need anything other than the "kit" they sent me. The coolant bypass, I just used the elbow they sent between the 2 hoses off the EGR.
Biggest pain, getting the DPF out. It was like a puzzle, removed the dogbone and rocked the engine forward as much as possible, but the space seemed to small. Lots of cussing and fiddling with it and finally it popped out. In hindsight I would just drop the subframe if I were to do it again.
I loosely used the RawTek install guide, here.
TheMysticWizard is online now   Reply With Quote
Old June 26th, 2020, 11:52   #12
AaronB
I'm doing this now what a pain in my butt. I hate droppin GB the sub fram but probably will. It seems impossible for it to come out the bottom
Old June 29th, 2020, 06:05   #13
AaronB
Not to hijack but adding extra info. I lowered subfram and raised the trans up with a Jack and the dpf came out with some ease. I attempted to do so without lowering it but seemed impossible. I feel the mid pipe is a few inchs to short. They did not include anything to delete the cooler but I removed it and 90į the coolant lines together with a 5/8s 90į. Zipped tied the coolant lines out of the way. Also when I removed the cooler I noticed the egr pipe turns into a hose so I just used the egr block off and put it on the pipe and bolt/nutted it together. I just tucked the def fluid line and harness up under the black trays that tun along the side. Have about 50 miles on the car so far.
BuzzKen ALH EGR Delete and Racepipe Install thekrauthouse VW MKIV-A4 TDIs (VE and PD) 0 November 18th, 2015 07:45
Help Buzzken Exhaust install 2.0CR bobish TDI Power Enhancements 5 November 12th, 2015 13:43
Buzzken jjtoutt TDI 101 10 July 15th, 2015 18:14
Malone Stg2 w/Buzzken 2.5 Install nakedbee VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 28 April 12th, 2014 05:41
Page generated in 0.14470 seconds with 12 queries
[Output: 109.82 Kb. compressed to 91.78 Kb. by saving 18.04 Kb. (16.43%)]
