If you get good measured vacuum response using the output test on the N75, that points to the N75 being ok. Worth swapping with the N18 though if that works for 99.5s.
Did you try taking off the actuator arm by removing the circlip, and feeling the VNT lever by hand? It is difficult to really assess the mechanism with the spring pressure of the actuator working against it. The VNT ring can wear a small groove into it which can cause intermittent sticking separate from the general crunchiness due to carbon buildup.
I'm still confused about your log from post #15, and why the ECU is requesting full duty cycle (reduce boost) on the N75 when you were underboosting. Did you sort out the potential boost leak from the intercooler?
