6 69newt Member Joined Mar 12, 2014 Location central ill. TDI 2013 passat sel tdi, 2015 gsw s 6sp manual Jul 14, 2017 #1 Put taller tires on gsw now speedometer is off by 7%. I have vcds but having trouble figuring it out. Any help would be appreciated.
jerrymander Veteran Member Joined Feb 11, 2012 Location ur mum TDI f Jul 21, 2017 #2 You can't. The value is hardcoded in the MQB. This is a departure from previous cars, which did have a speedometer impulse number.
