KraftwerkB6
washed my car this past weekend and found the rear driver side door rubber weather seal is coming off the door in the lower corner.
going to ask service at work today and see either vw will install new seal or just 3m double sided tape it. i hope a new seal will be the right choice though.
Also checked it today on 2 other JSW's that came off the truck and it seems right on the corner portion of the door (only the drivers rear) is where it is starting to peel.
so check yours out and post up and see if this might be a common thing but no one has saw it yet. and i will post up with what warranty says.
