Ironforger
- Joined
- Feb 18, 2003
- Location
- Lawrenceville, NJ.
Hello, 1999 Beetle TDI approx 100,000 miles. Today the battery light came on, so I checked it with a volt meeter, approx 12.14 volts at idle. Turn off the car, battery then shows 12.75 volts.
Bottom line, It's not charging and shows more juice when engine off since no current is drawn.
Should I first check/troubleshoot the voltage regulator? If so, how do I test it? Then how do I also check the alternator?
Thanks!
Thanks!
