assuming the immobilizer has been dealt with.The immobilizer would keep you from doing much of anything except sitting there cussing.
Not even close to what the OP is trying to do.My Beetle still has the original ECU - recoded from 4 speed automatic to 5 speed manual when that conversion was done. As far as the engine working - no issues ( and now I have an RC stage 2).
Not trying to do.Not even close to what the OP is trying to do.
If they didn’t recode the transmission, what makes you think they turned on the cruise control. Open the engine>login screen in vcds and it should tell you the code to turn it on.Although I don't think cruise is working but that might be something else
Not sure if this is the cause (haven't had a chance to take it around the block again yet, it's unregistered and uninsured right now heh... can't get caught slippin by the popo so I'll wait until after dark) but the clutch cruise switch wasn't being closed by the clutch pedal. I pulled out the little rod on the switch a bit (it has this ratchet mechanism) and now it closes when the clutch pedal is depressed. So I will see if that fixed the cruise problem if not then to VCDS it is.If they didn’t recode the transmission, what makes you think they turned on the cruise control. Open the engine>login screen in vcds and it should tell you the code to turn it on.
