ghohouston
All items are located in Lewisville, Texas.
3" turbo back Kerma exhaust, including down pipe. Down pipe was damaged when car hit a curb, and has been brazed. $350.
Dlc1019 Bosio's mounted on Injectors, iirc, roughly 60k miles. $350. Injectors were set up by Drivebiwire. Ran great, even on stock tuning.
10mm Vp37 injection pump, came off of my car, engine was consuming oil. Have a vw receipt showing it was replaced when the car belonged to the previous owner at 30k ish miles iirc, can verify, so likely has around 250k on it, but worked perfectly. Still mounted to the block. $250
Full set of black leather heated manual mk6 seats, was going to swap into my mkiv, but life happens... $850, not really interested in shipping, unless the buyer will figure it out.
2001 Mkiv Tdi roller, grey interior with silver paint, no seats. $900. In Texas its whole life, no rust, paint overall is decent, but has a few dings and whatnot. 285k miles, was running, until i pulled engine to swap into my other car.
No idea on suspension, interior isn't great, and is missing a few pieces.
This is more of a parts car, or if one of you northerners want a great chassis to swap your engine/interior into. Can throw in a Diesel 5 speed with cracked bellhousing, but in my opinion, still plenty usable, and worked great prior to car hitting a curb, for an additional $500.
Can also throw in an alh block for $150, with questionable health. Lots of blowby, still fired right up in cold, started using LOTS of oil though. Head is off, and my dumbass damaged the cam journals upon valve spring removal, also needs a valve job with new valves, one guide is broken. Head is also yours, for an additional $100. Not sure if it is repairable or not.
I will ship the head. If someone wants the block, or car, will have to come pick up, or figure out shipping. Title to the car is not in my name, but I do possess it. I took it as trade in from a good friend.
Also have an extra silver trunk lid, tdi jetta badges. $200.
Will have pics hopefully tomorrow.
