FletchMan
- Joined
- Apr 1, 2006
- Location
- Black Hills
- TDI
- 2006 Jetta, 99.5 Jetta...previously owned 2000 Beetle and 1990 Jetta 1.6
I'm getting a code on VCDS (P2015) that seems to be associated with a bad EGR cooler. I keep reading about a buzzing or hissing sound that this typically makes and that seems like a good description to me, too. It almost sounds like it's coming through the vents in the middle of the car - and like the sound the AC compressor makes when it turns on....except it's constant and correlates with RPMs as the gas pedal is pressed. Is that consistent with what others have heard?
It's confusing because I first thought I had an anti shudder valve problem and still haven't ruled that out. If it's an EGR problem, I'll just delete and tune but don't want to do that unnecessarily.
Thanks for any input.
