What Dot??? to use for brake fluid
foxstoy
Kenosha, WI
2000 Jetta GLS, 5 speed , Red
I was wondering what Dot to use? The Napa guys said Dot 3. But I did not think that was correct /images/graemlins/smirk.gif /images/graemlins/confused.gif
ruking
San Jose area, CA
2003 VW Jetta, 5 M, Reflex Silver: 09 Jetta, 6 Sp DSG, Candy White: 12 VW Touareg, 8 Sp A/T, Flint Gray
DOT 4 is the specification!
tjl
California, USA
2001 Golf GLS
[ QUOTE ]
[/ QUOTE ]
The a4 cars specify DOT 4.
If you are not sure about a specific car, choose DOT 4 over DOT 3, since DOT 4 brake fluid meets DOT 3 specifications as well (but has higher boiling points) and does not cost significantly more. Do not mix DOT 5 brake fluid with DOT 3 or DOT 4 brake fluid.
