Plastervan
Hi all,
New to here and my first post. its agreat site you have here . have read many post b4 writing this post and gained some understanding of where to trouble shoot with the cars problem. I am not a mechanic or a diy er normally but the other halves golf has left me in this predicament .
Vw Golf 1.9 tdi 1998. 90,000 miles. Off the road now for 3 weeks.
It Will crank but won't fire. Our regular mechanic has tried but can not fix it. Had it to vw dealer , they said it had no error codes and that the timing was fine. To expensive to leave it with them for more work so towed it home.
Glow plg light comes on and goes off as normal. Battery seams good. We have check all the fuses. Replaced the 109 relay. Put a new EGR valve on. Replaced all four glow plugs. Changed shut off valve. Replaced engine crank shaft sensor.. Opened up a couple of injectors and cranked and fuel comes out.
Really struggling where to go from here, any help would be really appreciated.
Marc
Marc
