Annalisa
Hi, I have a 2003 Jetta Wagon Tdi. It has an auto trans (unfortunately), which I had rebuilt last year for $3072. A little over a year later (and around 19,000 miles later), I'm having some problems. The brake light comes on with hard acceleration and there is a lot of bucking on even mild acceleration on the lower gears when starting. The computer code reads "torque converter", which I had replaced last year. Do you think that this is a computer issue (the mechanic says that this is likely the case, as in many older VWs apparently) or more transmission issues? "Torque converter" was the code last year on the computer read too. Sucks that last year that meant "auto trans rebuild" and this year it means that the car needs a new computer. Technically, it's still under warranty for the trans rebuild. Any thoughts? I am way out of my league here. Thanks!
Oh, also, the mechanic wiped the codes and the car drove just fine for a few hours. So... maybe that indicates computer? I don't know... Help...
