robnitro
I was speaking to Justin (oldpoopie) about the stiffer dogbone bushings, and he said that his tranny mount was messed up a bit because the stiffer dogbone bushing pushes back harder which transmits to the other 2 mounts.
I also didn't like the vibration, so I decided to test something out while I had my skidplate off. I took apart the dogbone bushing. I saw how the stock smaller one (which is pushed upon when reversing or under deceleration) is pretty stiff anyhow. The stock bigger one (which is under load under accel) is quite soft, especially because it has that cut in it. So I put the smaller stock in and the stiffer bigger mount (I also drilled some holes in it, but I don't think that softened it that much anyhow). Tighten the bolt all the way as the smaller stock one will compress anyhow, and hold it nice and tight (but still flexible).
Anyhow, it works great now, a hint of vibration at idle, and almost none when accelerating, even at low rpms! It doesn't have the horrible slop that the stock one has. In fact I can't really tell if this has more slop than when both were stiff!
Picture below:
The left one, smaller one leave it there, and change the bigger one (which is very sloppy stock) to the stiffer poly one.
Picture below:
