Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old February 3rd, 2013, 14:34   #1
hoorders
hoorders's Avatar
Default Block heater or frost heater...anyone have one?
Hi everyone,
Just wondering if any of you have a block heater or a frost heater on your TDI. I read on the forum that the canadian cars came with the frost heater. Ihave no idea if my 2003 TDI has this. Dont even know where to look or if it would have a plug like a traditional block heater.
If someone has one...if you could post some pics that would be great.
Thanks.
hoorders is offline   Reply With Quote
Old February 3rd, 2013, 14:47   #2
GD
GD's Avatar
No A4 Jetta's came with a block heater from the factory. Most folks retro fit in a frost heater per se. You will see this fitted in line with the oil cooler. Have a search on the forums and take a look. Canadian Tire and Partsource sell the frost heater.
TDI'ers Do it Better!
2007 Benz ML320 CDI too many toys to list
2011 Jetta TDI (CJAA) Highline DSG Reflex Silver 165,000 kms
2004 Jetta TDI PD (BEW) Platinum Metallic Grey 340,000 kms SOLD
2000 Jetta TDI ALH Black 398,000 kms, TT LCA Bushings, TB changed at Windex GTG SOLD
GD is offline   Reply With Quote
Old February 3rd, 2013, 14:54   #3
hoorders
hoorders's Avatar
Thats great that Canadian Tire sells them. There is one just a couple of mins from my place. Might have to go check it out.
Thanks.
Old February 3rd, 2013, 15:31   #4
Vince Waldon
Vince Waldon's Avatar
To be clear, Canadian Tire sells coolant heaters, like this Temco unit:
http://www.canadiantire.ca/AST/brows....jsp?locale=en
To be used on our TDIs you will also need to fab a mounting bracket and track down a specific hose that goes in place of one of the existing oil cooler hoses.
You can also buy an actual Frostheater, which is a complete kit including the coolant heater, the bracket, the specific hoses and clamps, etc, from Terry:
www.frostheater.com
All depends on how much DIY you want to do.
It's also worth noting that "frostheater" is a great search term to use here... hundreds and hundreds of threads on this, the pros and cons of rolling your own, etc etc etc.
Vince Waldon Edmonton AB Canada
Canadian Grizzly's excellent low-power/limp mode troubleshooting guide
VW's TSB for scientifically tracking down parasitic current drains
Vince Waldon is offline   Reply With Quote
Old February 3rd, 2013, 15:35   #5
hoorders
hoorders's Avatar
Cool. Thanks for the clarification. I checked out the 'frost heater' and it seems like they have done a great job withe the product and installation instructions. I wonder if the Canadian Tire unit has GOOD clear instructions.
Old February 3rd, 2013, 17:32   #6
mecne
mecne's Avatar
TDI(s): 15 Jetta TDI
No instructions . Great diy on the forums , many posts on this topic in the ontario section .
I've done the CT one and its not that hard, but didn't fit as nice as the Frostheater .
My recomendation , spend the little more on the Frostheater you won't regret it .
M
15 Jetta TDI
10 MB ML350 Bluetec
mecne is offline   Reply With Quote
Old February 3rd, 2013, 18:11   #7
hoorders
hoorders's Avatar
Yes, I think the Frostheater one is the way to go. Will order one this week.
Old February 3rd, 2013, 18:36   #8
craig01b
craig01b's Avatar
TDI(s): None
It's febuary...worst is over now...haven't plugged in once this winter, that is probably it...
All retired, bought a Subaru.... all wheel drive, and a little bigger than the high line. Time will tell!
craig01b is offline   Reply With Quote
Old February 3rd, 2013, 19:15   #9
mecne
mecne's Avatar
Been using the frostheater on my 01 religiously, but it stays outside .
My wife's Golf resides in the garage , and has been fine with out it as it's been sitting on the bench.
Added the FrostHeater I had on the bench into the Golf today .. Did the ThermoStat and Temp Sensor so I got everything done while the coolant was drained .
Was doing good .. had caught all the coolant .. even when I pulled the oil cooler line for the FrostHeater . Then I pulled the temp sensor and had Niagara Falls off the back of the motor (first time changing one) .. DOH!! good thing I keep a good amount of absorball on hand ..
I'm still amazed the golf has an intact factory belly pan and sides .
Temp gauge is now pegged at 90 degrees and blowing lots more heat .. was reading 60 degrees at operating temp in VCDS.
M
15 Jetta TDI
10 MB ML350 Bluetec
Old February 3rd, 2013, 20:48   #10
LNXGUY
LNXGUY's Avatar
Identical heating units (They are Temro), only difference is the custom hoses with the 'Frostheater' kits...
Bill
LNXGUY is offline   Reply With Quote
Old February 3rd, 2013, 22:14   #11
Vince Waldon
....and the laser cut bracket that fits perfectly on the base of the battery box,and the loom for both hoses, and the detailed instructions, and the over-the-phone support, and the bag of M&Ms
Not affiliated with Frostheater in any way BTW...just a happy customer. I have two Jettas and have tried both approaches...like I say...it all hinges on how much DIY you are comfortable with.
Old February 4th, 2013, 07:50   #12
LNXGUY
LNXGUY's Avatar
.....and the extra what.... $70? You forgot to mention that.
Regardless of what kit the OP goes with, a coolant heater is the best thing you can do for your TDI in the winter.
Bill
Old February 4th, 2013, 07:57   #13
hoorders
hoorders's Avatar
Im definitely going to check out the unit Canadian Tire has. Im pretty handy and can fab up brackets, etc no problem. So if I can save some $$$ might just go with the Canadian Tire one.
Old February 4th, 2013, 09:02   #14
LNXGUY
LNXGUY's Avatar
The brackets that come with the retail Temro kit are fine... It's a dead easy install.. Hang it off the battery bracket, splice into the lower oil cooler hose, then back into the hose below the vac pump. Simple stuff.
Bill
Old February 4th, 2013, 11:25   #15
imo000
imo000's Avatar
Fuel Economy: Good enough
A less complicated option is an oil pan warmer. I have one on the '99.5. Just starred using it a couple of weeks ago and it's great.
imo000 is offline   Reply With Quote
Jetta 2009 TDI Block Heater/Tank Heater carrot TDI 101 12 January 12th, 2016 18:42
2005-09' a5 mk5 mkv jetta golf frost heater AC coolant heater krousej Private TDI Items for Sale/Wanted 1 January 23rd, 2013 14:14
ZeroStart Frost Heater/Block Heater $40 Purplecomputer226 Private TDI Items for Sale/Wanted 3 August 27th, 2011 08:04
New A3 TDI Heater/ Frost Heater $50 Bopper Private TDI Items for Sale/Wanted 0 May 2nd, 2006 11:33
oil reservoir heater or engine block heater rmunsen VW MKIV-A4 TDIs (VE and PD) 4 November 7th, 2002 19:25
Page generated in 0.15439 seconds with 11 queries
[Output: 130.22 Kb. compressed to 108.56 Kb. by saving 21.67 Kb. (16.64%)]
