Old March 18th, 2012, 20:49   #1
ecaddy
Angry Can't get my Transmission Back On - 2006 Jetta TDI DSG dmf
Need some guidance- spent all day messing with this car and now I'm ready to give up. 2006 Jetta TDI with dsg auto trans. Her's some info and pictures that might help.
This is what I wrote to Jasontdi-
Hi Jason,
I went on your website to get your info so I could bring my car to you for the dmf swap but when I saw that you were back up for the next month or so I decided to try it myself. I have done tons of work on American cars, even swapping engines and transmissions so I figured I should be able to do it. Well that was a naive assumption.
I first did the dsg service since I just bought the car and didn't know what service was done. After that I proceeded to remove the transmission, removed the old dmf, cleaned everything up, and installed the new dmf. I then, after taking all day today(the second day of this job), slowly got the transmission back in. Now for the problem.
I can not get the transmission to seat properly onto the engine. I have loosened everything several time and tried re-tightening in different methods, putting the jacks in different locations and pitches, ect...
But for the life of me I can't get it to go together that last 1/4 inch. I thought it might be the gears not lining up properly so I kept pulling the transmission back until I could take a screw driver in the starter hole and spin the flywheel and then slowly tighten everything back up. Is there a trick to getting this back together right or should it just slide back together? I can tighten one side but then I can't tighten the opposite side, I try doing it all at the same rate but it still comes down to one side being like an 1/8" away and the opposite side 1/4" away and then nothing. If I try and force it stuff will crack.
If you weren't backed up I would just have the car towed to you so you could finish everything up, shouldn't take more than an hour for someone who's knows these cars. What should I try next? DO you think the flywheel or gears are screwed up some how? I took a couple of pictures and will attach them. Any help would be appreciated. Next time I will wait until you are available and just rent a car or something, this has been a nightmare!
ecaddy is offline   Reply With Quote
Old March 18th, 2012, 20:59   #2
ecaddy
Default Pictures of what i'm describing
Old March 18th, 2012, 21:06   #3
Seatman
Seatman's Avatar
Fuel Economy: No idea
It's definitley the right clutch kit and flywheel? They're exactly the same size as the one that came out? The clutch plate is lined up correctly and the right way round?
That's all I can think of, it does sound like the box needs to come back out to see what's actually going wrong.
In my experience with clutches as I'm sure yours too is the box tends to just slip right into place when it's lined up so something must be going wrong in there. Personally I think that's what I'd do in that position.
Seatman is offline   Reply With Quote
Old March 18th, 2012, 21:51   #4
MyAvocation
MyAvocation's Avatar
Seat, it's a DSG.
Caddy, you located in Chicagoland? If so I'm willing to lend a pair of hands. Just did mine a few months back.
I doubt the shaft is the culprit if you're only dealing with the last quarter inch.
"Never trust Internet quotes." - John F. Kennedy
MyAvocation is offline   Reply With Quote
Old March 18th, 2012, 22:17   #5
Seatman
Seatman's Avatar
Yeh but I thought the DSG still used a clutch and DMF but it was just done automatically instead of pressing the pedal?
Old March 18th, 2012, 22:38   #6
Jnitrofish
Jnitrofish's Avatar
Fuel Economy: Bad on short trips, good on long trips.
It does, but not like you are thinking. The transmission input shaft inserts directly into the DMF, and the clutch pack is inside the transmission.
[ 2005.5 :: 06/05 Jetta 5m Franko6 BEW Cam/Malone Tuned - Equipped for towing (Bosal/Airlift/Tekonsha) || 2005.5 :: 05/05 Jetta 5m Tuned (Wife's Car) || 2006 :: 02/06 Jetta DSG Malone Tuned (Dad's Car) ]
[ 4 TDI tally: 4 cam jobs, 5 timing belts, 4 alternator pulleys, 2 DMF, 1 G60/VR6, 1 Jetta ] [ Explained engine vibration
Jnitrofish is offline   Reply With Quote
Old March 19th, 2012, 00:13   #7
Seatman
Seatman's Avatar
Ah cool, you learn something new everyday.
Old March 19th, 2012, 00:33   #8
DPM
Fuel Economy: 38.5- 47 Forester, Citroen 55- 63
locating dowels?
DPM is offline   Reply With Quote
Old March 19th, 2012, 04:18   #9
D-Cell_Mekanick
Fuel Economy: 45ish
Where at in Illinois are you?
2014 Passat SEL TDI(GONE BUT NOT FORGOTTEN). Tungsten Silver exterior with Titan Black interior. I have VCDS HEX-USB+CAN, still learning how to use it.
D-Cell_Mekanick is offline   Reply With Quote
Old March 19th, 2012, 06:02   #10
ecaddy
I'm over by Fox Lake IL. I am going to back it all out now, Jasontdi told me that some have to line up just right to go in. I'm going to back it off and then turn the flywheel with a flat head until something falls into place. That is the hope anyway.
Old March 19th, 2012, 06:05   #11
ecaddy
Originally Posted by MyAvocation View Post
Seat, it's a DSG.
I'm just down the road from Round Lake. If your not busy today you should stop by, a different set of eyes on this might make a difference.
Old March 19th, 2012, 06:33   #12
D-Cell_Mekanick
Fuel Economy: 45ish
If the flywheel didn't mesh properly and you torqued the bolt to yield, you may want to replace them again.
Old March 19th, 2012, 06:47   #13
ecaddy
I'm going to pull it now to check it out, if anything is messed up I will definately fix it before putting back together, I also want to see the guide gear or grove that Jason was talking about.
Old March 19th, 2012, 09:16   #14
ecaddy
Talking THank God and JasonTDI
After several hours of suffering and prayer I was finally able to get the transmission back on. If anyone does this on there own and runs into this problem you need to back the transmission off, many times if necessary, turn the engine with a 19mm 12star on the harmonic balancer and try reseating. You turn the engine clockwise.
If this doesn't work then you will have to line everything up by eye so the gap is even all around the trans, then hand tighten the 4 large guide bolts, turn engine one rotation, if no seat, then gently close the gap a little with a small wrench on those 4 main bolts, turn again one rotation, and so on.
I was to the point of giving up so I figured screw it, I tried one last time and when I was tightening some more I heard that lovely pop sound and in it went.
Thanks to you all who are good hearted enough to share some time and experience, it is appreciated and you are definitely paying it forward! Good things are coming your way.
2006 Jetta TDi DMF DSG replacement - clunk rattle ecaddy TDI 101 12 March 20th, 2012 05:06
NEW DMF for 2006 DSG for sale kamakazi Private TDI Items for Sale/Wanted 0 November 26th, 2010 12:43
Tools and hardware needed for DMF replacement on 2006 Jetta?? DSG - BRM skglidden VW MKV-A5 Golf/Jettas 3 August 30th, 2010 10:00
2006 DSG DMF inspection??? Fireblade_rr VW MKV-A5 Golf/Jettas 53 July 29th, 2010 19:01
2006 dsg dmf failure jonathantingley VW MKV-A5 Golf/Jettas 7 April 17th, 2010 12:23
Page generated in 0.16495 seconds with 11 queries
[Output: 118.84 Kb. compressed to 99.43 Kb. by saving 19.41 Kb. (16.34%)]
