spen Active member Joined Jul 27, 2010 Location hull TDI golf 2 tdi Jul 18, 2013 #1 Are ALH injector nozzle the same as AHU?
T TDI Jim Veteran Member Joined Jul 10, 2006 Location Gaithersburg, Maryland TDI 1996 Passat, 1996 Passat Variant (RIP), 2002 Jetta Wagon, 1995 Passat Variant TDI conversion brought back from the dead, 1997 Passat Variant project, and returned 2014 Passat Jul 18, 2013 #2 Yes the injectors are the same for the AHU and the ALH engines. The nozzles are whatever you want to put on them.
Seatman Top Post Dawg Joined Apr 23, 2010 Location Scotland TDI 2014 Skoda rapid elegance 1.6 cr tdi Jul 18, 2013 #4 Only thing that might be different is the plug for the number 3 lift sensor if swapping complete injectors. Do you have a specific problem? Also, any decent pics of your Mk3?
