Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI (Diesel) Emissions
TDI (Diesel) Emissions This is a discussion about emissions from TDI's. Pro's cons of Diesels (including biodiesel) effects on the environment and how they compare to Gasoline and other fuel sources for Internal combustion engines.
Old July 16th, 2018, 13:14   #31
Pittdawg
Darkside Developments in the UK makes a universal fit race DPF; would love to hear if anyone has tried it or something similar.
Pittdawg is offline   Reply With Quote
Old July 16th, 2018, 13:15   #32
Pittdawg
Originally Posted by VeeDubTDI View Post
A stage 2 without DPF delete and a stage 2 with DPF delete are only about 5 horsepower difference. I wouldn't consider that a dramatic increase in power output.
That's contrary to almost every post that claims the DPF is the limiting factor; where did you get this info?
Old July 16th, 2018, 14:57   #33
crazyrunner33
crazyrunner33's Avatar
The DPF isn't as limiting as you'd imagine. A SCR equipped Cummins with the DPF and a deleted Cummins experiences zero measurable increase in fuel economy. The DPFs flow pretty well if they aren't clogged, the big kicker is the EGR usage which isn't much of an issue on an SCR equipped diesel engine. The stock turbo is the biggest limiting factor. And DPF clogging typically isn't an issue on SCR equipped engines or ones with the EGR disabled.
'06 Jetta DSG: GTB1749VC, PD150 injectors, Malone tune, and some other stuff and things
'97 Cummins: It looks stock, does that count?
crazyrunner33 is offline   Reply With Quote
Old July 16th, 2018, 15:05   #34
GoFaster
Moderator at Large
A DPF needs to be close-coupled to the engine in order to minimize the need for active regeneration.
Look at where it is on a VW EA288 or on the latest M-B 4-cylinder engine. The path from the exhaust ports to the turbo to the catalyst is as short as possible and the DPF is in the same enclosure as the oxidizing catalyst.
That's not going to happen if you have connections and fittings in between, and it's not going to happen if you position the catalyst under-floor (as with the original layout of the VW common-rail TDI).
If it's tied directly to the engine, it heats up as quickly as possible and the operating temperature could reach the regeneration threshold during normal driving more frequently.
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
GoFaster is online now   Reply With Quote
Old July 16th, 2018, 17:30   #35
KERMA
KERMA's Avatar
Stock size is fine
Frankly the DPF is not an impediment to power IMO so really not much to gain here, other than the possiblility of a more reliable unit.
SO if you have a chance to design an upgraded DPF, I would replace the original cordierite filter element with a silicon carbide filter medium. It will cost more than stock VW, but will not crack as it is rated for much higher temperatures
You would also need to remember the nox catalyst if you want to have a chance at compliance
If you want it to work "correctly" there are some changes needed to the ecu internal model. Can't just slap on an extra injector or something hillbilly
HP is for show, TQ is for go.
celebrating 15 years of: http://www.kermatdi.com
kermatdi on facebook
No, no, you're not thinking; you're just being logical. - Neils Bohr
KERMA is offline   Reply With Quote
2010 CR 2.0 TDI DSG Mechatronics unit failure Specialized VW MKV-A5 Golf/Jettas 3 April 18th, 2014 18:50
2.0 cr tdi DPF delete 3inch down pipe Spencerhoag Private TDI Items for Sale/Wanted 3 January 18th, 2014 09:04
[FS] 2.0 CR TDI Downpipe w/Diesel Particular Filter (DPF), EGR + Cats Shaeet Private TDI Items for Sale/Wanted 3 October 28th, 2013 14:32
Is this how Passive Regeneration in the DPF works? HumbleSmoker TDI (Diesel) Emissions 1 January 29th, 2009 07:16
Page generated in 0.15898 seconds with 12 queries
[Output: 71.79 Kb. compressed to 63.72 Kb. by saving 8.07 Kb. (11.24%)]
