andytdiland
I need to get some insight into a problem I have with an 06 Jetta BRM engine. I get 500psi compression on 1,3,4 cylinder and the 2nd one I get 250psi. The engine smokes a little bit at start up but it clears up quick. Cold idle is lumpy, warm idle is good, no misfire codes, but the Mes Block 13 shows the injector 2 deviation at 2.99 at idle, when reved up it comes to 1.xx range.
What could be wrong here? Engine has barely 50k miles.
