B4 leaking heater core, any other tasks??
Ok, so I’ve finally got the heater core side of the hvac out. Pulled the core. It had a little leak, not as much as I thought with how stinky and foggy it was making the windscreen. Really hope that is/was my problem. I assume it was.
BUT! I’m in there. I’m ordering a heater core this week. What other “while I’m in there” bs should I take care of? I have pulled the disintegrating foam off of the blend doors. Do I need to pull the Ac and blower side off to tidy that up at all?
I am going to order all the coolant lines because I have a leak at the water pump. I probably should just do the timing belt and water pump during this debacle. But what else is there anyone can think of?
