Old December 4th, 2017, 21:40   #1
jrm
Fuel Economy: 42/52
Default Christmas lights & the NMS
Our local racetrack does a 2 mile long animated light display that you drive threw,( http://winterwonderlandportland.com/ ) requirement is you must drive with only parking lights- no head lights- I couldn't figure it out! They let me go, but with hazards on and the E-brake up one click to disable the DRL's but man, what a mess with the clicking of the hazards and the BEEEEEEEP from the "release parking brake" notification. Can this be fixed in VCDS? How does one drive or even idle with the parking lights on?
2013 Passat TDI SE+NAV 48MPG
2001 Honda civic 40MPG
1985 VW idi 1.6 Golf 55MPG http://www.youtube.com/watch?v=yo-YUR1_DaU
1996 Dodge mechanical Cummins 12V 2500 4x4 that gets 20MPG
1990 Toyota xcab 4x4 3.0 v6 (3.slow) 15MPG
jrm is offline   Reply With Quote
Old December 5th, 2017, 03:52   #2
oilhammer's Avatar
Fuel Economy: fantastic
Ha, that seems like a pretty dumb rule considering just how many cars are cursed with some sort of lame "uncontrollable" exterior lights. It isn't just Volkswagens.
Luckily, you can disable the DRLs with VCDS in the coding of the appropriate module, and if you want normal lights you can purchase a regular (often called European) headlamp switch.
That is how I have all my Volkswagens. Interestingly, I had to deal with this recently myself with my Sprinter, but that has a normal headlamp switch already and the DRLs go out when you turn the switch to the first running light position. Which is good, because its dedicated DRLs are quite bright and up high, and would have been right in the back window of the Accord in front of us going through the display.
www.cardocautomotive.com
Old December 5th, 2017, 13:01   #3
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
You need to install a Euro switch in order to do parking lights only. North American VWs have been like this for nearly two decades. I agree, it's annoying.
Disabling DRLs won't help this particular situation since the requirement is parking lights. Disabling DRLs will either give you all lights, including headlights, or no lights at all.
Trusted TDI Mechanics Map || TDIClub Chat
Old December 5th, 2017, 20:56   #4
BroncoAZ
So is it just the euro light switch, or does it need to be programmed too?
My Commuter: 2015 Passat TDI SE 6MT
Former TDIís: 2009 Jetta TDI - traded 09/2013, 2011 Touareg TDI - Bought back 2/26/2018
My Truck: 2006 Dodge 2500 4x4 Cummins
Wheelin Rig: 1987 Ford Bronco http://www.supermotors.net/registry/13
BroncoAZ is offline   Reply With Quote
Old December 5th, 2017, 21:58   #5
JSWTDI09
JSWTDI09's Avatar
It is just a Euro switch to turn on parking lights without headlights. Turning off DRLs (daytime running lights) requires programming or lifting the parking brake handle a notch.
Have Fun!
Don
2009 Jetta SportWagen TDI (gone but not forgotten)
2018 VW Tiguan SE (I wish it was a TDI)
JSWTDI09 is offline   Reply With Quote
Old December 6th, 2017, 09:09   #6
jck66
jck66's Avatar
Is there such a thing as a euro switch for the NMS? The car wasn't offered in Europe.
I had one on my B4 that did the trick for parking lights only (BTW that car had no "parking brake one notch to shut off DRL" trick - you had to go under the hood and unplug 'em like a man!)
jck66 is offline   Reply With Quote
Old December 6th, 2017, 09:14   #7
oilhammer's Avatar
Yes, because the NMS uses a common VAG headlamp switch from the corporate parts bin. Also, they DO sell the NMS Passat in other markets, most of which would get a normal headlamp switch anyway. I bet you can go down the assembly line here and see a few that are for export equipped that way.
The "Euro" moniker may not be the best name, more like "RoW" (Rest of World).
Old December 6th, 2017, 15:27   #8
Good Ol' Boy
VeeDubTDI's Avatar
Yes. We have one in our Passat. If you switch it to parking lights, the DRLs do not illuminate.
Old December 7th, 2017, 05:28   #9
compu_85
Gadget Guy
compu_85's Avatar
With VCDS, you can also put a DRL on/off setting in the "Lights & Vision" MFI menu, and also program the system such that the DRLs only come on when the headlight switch is in Auto.
-J
Present:
2013 Fiat 500e. 22,000 miles.
2014 Cadillac ELR. 23,000 miles.
2012 Passat SE TDI DSG. 112,000 miles. Factory Alarm, LED tails, Memory Seat, HIDs 38/48 MPG. Buy it from us!
2004 Touareg V10 TDI. 165,000 miles.
99.5 Jetta "GLX" TDI. 310,000 miles. Half way there!!! Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG.
1991 Mercedes 350SDL 230,000 miles, 70,000 on engine. 18/27 MPG.
Past:
1988 Audi 5000S Quattro, 1992 Jetta ECOdiesel, 1991 Jetta ECOdiesel.
Check out the official TDIClub Chat Room!
Originally Posted by BRUSSELS BELGIAN View Post
Maybe I should pay MYSELF to do bad work on my car!
compu_85 is offline   Reply With Quote
Old December 7th, 2017, 08:26   #10
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2017 to end of April 2018
While using the VCDS is a workable albeit very expensive solution if someone does not own one!
All interior bulbs to LED. Several VCDS modifications. Darker window tint. EVO skid-plate. Malone Stage 2, Winpower Projector headlights. Angel eyes.LED DRL's.24mm H&R rear sway bar.
Old December 7th, 2017, 09:36   #11
oilhammer's Avatar
VCDS is hardly what I would call "very expensive".
Would you like to see our shop's expenses for this month for some of our software for other makes?
The Toyota system alone is $1100 every year. Every year. And it will stop working after a year, it isn't like it just won't do updates any more. It stop working.
I am still using the same VCDS cable I bought 15 years ago. Every update has been free.
Old December 7th, 2017, 21:39   #12
jrm
Fuel Economy: 42/52
I have the cable, was my first purchase- I'm home next week so i'll dig in coding and kill the DRL and check out that ROW switch, iv needed parking lights a few times now as I'm also a rural emergency responder and iv had to let it idle in extreme weather with the headlights on- cant shut it down with a weak heater core
Old December 8th, 2017, 10:37   #13
Good Ol' Boy
VeeDubTDI's Avatar
jrm:
https://www.amazon.com/Headlight-Par...dp/B01LZBUJP7/
That's similar to what you're going to need for your Passat, although I would personally be skeptical of the quality of a $15 light switch. We paid about $50 for ours back in 2012, but I don't remember where we bought it from.
NMS Maintenance Sale NMS Engine Oil, DSG Fluid & Filters Costello Private TDI Items for Sale/Wanted 1 March 25th, 2017 16:58
H&R SS Street Performance Coilovers for B6, NMS Passat & CC TurboBucho Private TDI Items for Sale/Wanted 1 September 25th, 2016 06:23
Got Christmas lights? JSW 2014 edition cwescapexlt4x4 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 5 December 15th, 2014 09:20
Got Christmas lights? JSW edition cwescapexlt4x4 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 11 December 19th, 2013 09:12
All lights flashing like a Christmas tree Jibeho TDI 101 10 January 17th, 2010 07:12
Page generated in 0.11595 seconds with 13 queries
[Output: 123.80 Kb. compressed to 104.68 Kb. by saving 19.12 Kb. (15.44%)]
