sundevil36
I am planning on replacing the coolant temp sensor, the manual says the car hols 6 liters of coolant total, will a majority of that drain out in the replacement process? Will a gallon of G12 (3 and change liters) refill it or should I get more or less? I've seen people reuse the coolant if its caught in a pan, but that makes me nervous as any dirt or gunk caught up in the liquid on the way to the pan could be problematic, right?
Second, my ASV wiring is frayed due to the known corrugated tubing rubbing issue, can I splice/solder any ol' 20 gauge wire to the existing harness? And once that is fixed, is there anything that can be put on the outside of those wires to prevent further fraying?
Thank you all for the help, I've fixed several issues with all of your guidance and knowledge!
