Hi all,
I am still recovering after a recent head, cam, and glow plugs. All this was from FrankTDI and was an excellent resource and great parts.
I had the head redone by him after a failed lifter that slightly tore up the cam journal. New head gasket, cam, lifters, T belt and hardware. The mechanical timing was near dead on, and with a little wiggling I could get all the alignment tools back in, and the crank mark was within 1/8” of the TDC mark. The timing on the vag com was adjusted so it was right in the middle of the graph. It all went back together good but had some long starts when the weather was warmer.
Now that the weather is colder, this got worse. I replaced the injectors, IQ set to 6. Slightly better fuel economy (45mpg with 2 people and some gear / tools) the hard cold start is still present, and may be even a little worse. This is when the car is cold as in single digits, and when the car is kept warm in a shop it still cranks long. It takes 2+ glow plug cycles, and trying to crank 2-3 times for it to start. When it does start and warms up it runs excellent. Lots of power, no smoke, sounds very good. I verified that on the long cold starts no air bubbles are present in the clear fuel hose. Fuel filter has about 10K on it. My glow plugs and harness were replaced 15K ago. It seems to start with plenty of RPM as it always has in the past 7 years.
What I may do from here:
Check glow plug amperage
Recheck mechanical timing, and timing with vagcom??
What else am I missing here? Any other suggestions? Thanks!!!!
